PDB-C137
PDB-C137
    LUNAOPTOELECTRONICS(Luna Optoelectronics)
    Through Hole
    PHOTODIODE BLUE 1.00MM SQ T1 3/4
PDB-C137 数据手册
PHOTONIC Silicon Photodiode, Blue Enhanced Photoconductive DETECTORS INC. Type PDB-C137 , with daylight filter Type PDB-C137F PACKAGE DIMENSIONS INCH [mm] 0.220 [5.60] Ø0.197 [5.00] 0.020 [0.51] SQ 2 PLACES 0.200 [5.08] CHIP POSITION ACTIVE AREA SURFACE 1.043 [26.5] 0.059 [1.50] MAX C L 0.100 [2.54] C L 40° VIEWING ANGLE CATHODE 0.984 [25.0] ANODE CLEAR PLASTIC (PDB-C137) BLACK PLASTIC (PDB-C137F) 0.038 [0.97] 0.342 [8.70] 0.043 [1.09] SQ 0.034 [0.86] SQ ACTIVE AREA T 1 3/4 PLASTIC PACKAGE ACTIVE AREA = 0.74 mm2 DESCRIPTION: The PDB-C137 detector is a 0.74 mm2 planar pin photodiode packaged in a T 1 3/4, water clear plastic housing. Designed for high speed, low capacitance, photoconductive applications. The PDB-C137F includes a daylight filter. -40 +80 O TS Soldering Temperature* +260 O IL Light Current C C mA 0.3 0.2 0.1 0 *1/16 inch from case for 3 secs max WAVELENGTH (nm) ELECTRO-OPTICAL CHARACTERISTICS (TA=25OC unless otherwise noted) SYMBOL CHARACTERISTIC TEST CONDITIONS MIN TYP ISC Short Circuit Current H = 100 fc, 2850 K ID Dark Current H = 0, V R = 10 V Shunt Resistance H = 0, V R = 10 mV TC RSH RSH Temp. Coefficient CJ Junction Capacitance RSH λrange 28 MAX UNITS mA 35 2 10 nA 1000 MΩ H = 0, V R = 10 mV -8 % / oC H = 0, V R = 0 V* 4 pF Spectral Application Range (without daylight filter)** λp Spectral Response - Peak VBR Breakdown Voltage I = 10 m A NEP Noise Equivalent Power VR = 10 V @ Peak Response Time RL = 1 KΩ VR = 10 V tr 1200 Operating Temperature Range 0.4 1100 TO C 900 O 1000 +100 * * * * * * * * * * * * * * * * * 800 -40 0% =10 QE 0.5 700 Storage Temperature 0.6 600 TSTG 500 V 500 50 400 Reverse Voltage 300 VBR SPECTRAL RESPONSE 0.7 190 ABSOLUTE MAXIMUM RATING (TA=25OC unless otherwise noted) SYMBOL PARAMETER MIN MAX UNITS APPLICATIONS Smoke detectors Light dimmers TV & VCR remotes I.R. receivers RESPONSIVITY (A/W) FEATURES Photoconductive High speed Low cost 500 400 1100 950 15 nm 25 V 1.5x10 -14 10 nm W/ Hz nS Information in this technical data sheet is believed to be correct and reliable. However, no responsibility is assumed for possible inaccuracies or omission. Specifications are subject to change without notice. *f = 1 MHz, ** daylight filter= 700 - 1100 nm [FORM NO. 100-PDB-C137 REV B]
PDB-C137 价格&库存
很抱歉,暂时无法提供与“PDB-C137”相匹配的价格&库存,您可以联系我们找货
