PDB-C163
PDB-C163
    LUNAOPTOELECTRONICS(Luna Optoelectronics)
    2-SMD
    PHOTODIODE BLUE 2.03MM SQ CERMC
PDB-C163 数据手册
PHOTONIC Silicon Photodiode, Blue Enhanced DETECTORS INC. Photoconductive Type PDB-C163 PACKAGE DIMENSIONS INCH [mm] PHOTODIODE CHIP .167 [4.24] .068 [1.73] .050 [1.27] .075 [1.91] .055 [1.40] .019 [ 0.48] .025 [0.64] C .068 [1.73] .250 [6.35] METALIZED CERAMIC CLEAR ENCAPSULATE A 2X SOLDER PLATE CATHODE SOLDER PAD .068 [1.73] SQ .059 [1.50] SQ ACTIVE AREA ANODE SOLDER PAD METALIZED CERAMIC PACKAGE ACTIVE AREA = 2.03 mm2 DESCRIPTION The PDB-C163 is a silicon, PIN planar diffused, photodiode. Ideal for many OEM pulsed oximeter probe assemblies. Packaged in a metalized ceramic substrate with top side pre-tinned solder contacts. Light Current O 5.0 C mA 0.3 0.2 0.1 0 *1/16 inch from case for 3 secs max WAVELENGTH (nm) ELECTRO-OPTICAL CHARACTERISTICS (TA=25OC unless otherwise noted) SYMBOL CHARACTERISTIC TEST CONDITIONS MIN TYP ISC Short Circuit Current H = 100 fc, 2850 K ID Dark Current H = 0, VR = 10 V RSH Shunt Resistance H = 0, VR = 10 mV TC RSH RSH Temp. Coefficient CJ Junction Capacitance MAX UNITS mA 20 25 100 500 MΩ H = 0, VR = 10 mV -8 % / oC H = 0, VR = 10 V** 7 pF λrange Spectral Application Range Spot Scan λp Spectral Response - Peak Spot Scan VBR Breakdown Voltage I = 10 mA N EP Noise Equivalent Power VR = 10 V @ Peak Response Time RL = 1 KΩ VR = 50 V tr 1200 IL +240 C 1000 Soldering Temperature* -40 C 1100 TS +80 O 800 Operating Temperature Range O 0.4 900 TO +100 % 00 =1 QE 0.5 600 -45 0.6 700 Storage Temperature V 400 100 500 TSTG Reverse Voltage 190 VBR SPECTRAL RESPONSE 0.7 300 ABSOLUTE MAXIMUM RATING (TA=25OC unless otherwise noted) SYMBOL PARAMETER MIN MAX UNITS APPLICATIONS Pulsed oximetry Glucometers Pulse meters RESPONSIVITY (A/W) FEATURES High speed Specially matched to 660 nm and near IR emitters 1.0 350 1100 950 50 10 75 1.0x10-14 35 nA nm nm V W/ Hz nS Information in this technical data sheet is believed to be correct and reliable. However, no responsibility is assumed for possible inaccuracies or omission. Specifications are subject to change without notice. ** f = 1 MHz [FORM NO. 100-PDB-C163 REV A]
PDB-C163 价格&库存
很抱歉,暂时无法提供与“PDB-C163”相匹配的价格&库存,您可以联系我们找货
