PDB-V103
PDB-V103
    LUNAOPTOELECTRONICS(Luna Optoelectronics)
    TO-46-2,金属罐
    PHOTODIODE BLUE 2.03MM SQ TO-46
PDB-V103 数据手册
PHOTONIC Silicon Photodiode, Blue Enhanced Photovoltaic Type PDB-V103 DETECTORS INC. PACKAGE DIMENSIONS INCH [mm] WINDOW CAP (WELDED) Ø0.184[4.67] 0.150[3.81] 0.040[1.02] Ø0.155[3.94] 0.060[1.52] WIRE BONDS CL 0.500 [12.70] MIN 45° CL Ø0.210[5.33] CL 0.100[2.54] CL 58° VIEWING ANGLE 0.042 [1.06] ANODE Ø0.018[0.46] HEADER PHOTODIODE CATHODE Ø0.018[0.46] 0.068[1.73] SQUARE 0.059[1.50] SQ ACTIVE AREA TO-46 HERMETIC CAN PACKAGE ACTIVE AREA = 2.03 mm2 DESCRIPTION The PDB-V103 is a silicon, PIN planar diffused, blue enhanced photodiode. Ideal for low noise photovoltaic applications. Packaged in a hermetic TO-46 metal can with a flat window. Light Current O 0.5 C mA 0.3 0.2 0.1 0 *1/16 inch from case for 3 secs max WAVELENGTH (nm) ELECTRO-OPTICAL CHARACTERISTICS (TA=25OC unless otherwise noted) SYMBOL CHARACTERISTIC TEST CONDITIONS MIN TYP ISC Short Circuit Current H = 100 fc, 2850 K ID Dark Current H = 0, VR = 10 V RSH Shunt Resistance H = 0, VR = 10 mV TC RSH RSH Temp. Coefficient CJ Junction Capacitance MAX UNITS mA 20 24 1 10 GΩ H = 0, VR = 10 mV -8 % / oC H = 0, VR = 0 V** 180 pF 50 λrange Spectral Application Range Spot Scan λp Spectral Response - Peak Spot Scan VBR Breakdown Voltage I = 10 mA N EP Noise Equivalent Power VR = 10 mV @ Peak 5.9x10-15 Response Time RL = 1 KΩ VR = 0 V 400 tr 1200 IL +240 C 1000 Soldering Temperature* +125 C 1100 TS -40 O 800 Operating Temperature Range O 0.4 900 TO +150 % 00 =1 QE 0.5 600 -55 0.6 700 Storage Temperature V 400 75 500 TSTG Reverse Voltage 190 VBR SPECTRAL RESPONSE 0.7 300 ABSOLUTE MAXIMUM RATING (TA=25OC unless otherwise noted) SYMBOL PARAMETER MIN MAX UNITS APPLICATIONS Instrumentation Character recognition Laser detection Industrial controls RESPONSIVITY (A/W) FEATURES Low noise Blue enhanced High shunt resistance High response 350 1100 950 30 150 pA nm nm 50 V W/ Hz nS Information in this technical data sheet is believed to be correct and reliable. However, no responsibility is assumed for possible inaccuracies or omission. Specifications are subject to change without notice. **f = 1 MHz [FORM NO. 100-PDB-V103 REV B]
PDB-V103 价格&库存
很抱歉,暂时无法提供与“PDB-V103”相匹配的价格&库存,您可以联系我们找货
