PDI-V106-F
PDI-V106-F
    LUNAOPTOELECTRONICS(Luna Optoelectronics)
    TO-5
    PHOTODIODE IR 10.00MM SQ TO-5
PDI-V106-F 数据手册
PHOTONIC DETECTORS INC. Silicon Photodiode, Near I.R. Photovoltaic Type PDI-V106-F PACKAGE DIMENSIONS INCH [mm] Ø0.325 [8.25] WINDOW CAP (WELDED) 0.030 [0.76] Ø0.250 [6.35] CL 0.168 [4.26] 0.075 [1.91] WIRE BONDS 0.500 [12.70] MIN 45° Ø 0.358 [9.09] 55° VIEWING ANGLE CL 0.200 [5.08] 0.035 [0.89] CL ANODE Ø0.018 [0.46] CATHODE Ø0.018 [0.46] I.R. PASS FILTER HEADER PHOTODIODE CL 0.154 [3.91] SQ Ø0.1404 [Ø3.567] ACTIVE AREA TO-5 HERMETIC CAN PACKAGE ACTIVE AREA = 10.00 mm2 500 C mA 0.1 0 WAVELENGTH (nm) *1/16 inch from case for 3 secs max ELECTRO-OPTICAL CHARACTERISTICS (TA=25OC unless otherwise noted) SYMBOL CHARACTERISTIC TEST CONDITIONS MIN TYP ISC Short Circuit Current H = 100 fc, 2850 K ID Dark Current H = 0, V R = 10 V Shunt Resistance H = 0, V R = 10 mV TC RSH RSH Temp. Coefficient CJ Junction Capacitance RSH λrange λp V BR NEP tr 1200 Light Current O 0.2 1100 IL +240 C 0.3 900 Soldering Temperature* -40 0.4 1000 TS +80 O C 800 Operating Temperature Range O 0% 700 TO +100 0 =1 QE 0.5 600 -55 0.6 500 Storage Temperature V 400 TSTG 100 300 Reverse Voltage 0.7 190 V BR SPECTRAL RESPONSE RESPONSIVITY (A/W) DESCRIPTION The PDI-V106-F is a silicon, PIN planar I.R. pass visible rejection diffused photodiode with NIR pass, visible Match to I.R. emitters light rejection optical filter. Ideal for low noise photovoltaic NIR applications. PackHermetic package aged in a hermetic TO-5 metal can with a flat window cap. ABSOLUTE MAXIMUM RATING (TA=25OC unless otherwise noted) SYMBOL PARAMETER MIN MAX UNITS APPLICATIONS I.R. detector I.R. laser detector Photo-interrupters Industrial controls FEATURES Low noise 90 MAX UNITS mA 112 300 500 pA 2 GΩ H = 0, V R = 10 mV -8 % / oC H = 0, V R = 0 V** 1200 pF Spectral Application Range Spot Scan Spectral Response - Peak Spot Scan Breakdown Voltage I = 10 m A .2 700 1100 950 30 nm 50 Noise Equivalent Power VR = 10 mV @ Peak 1.0x10 Response Time RL = 1 KΩ VR = 0 V 800 nm V -14 W/ Hz nS Information in this technical data sheet is believed to be correct and reliable. However, no responsibility is assumed for possible inaccuracies or omission. Specifications are subject to change without notice. ** f = 1 MHz [FORM NO. 100-PDI-V106-F REV A]
PDI-V106-F 价格&库存
很抱歉,暂时无法提供与“PDI-V106-F”相匹配的价格&库存,您可以联系我们找货
