PDB-V105
PDB-V105
    LUNAOPTOELECTRONICS(Luna Optoelectronics)
    TO-5
    PHOTODIODE BLUE 4.48MM SQ TO-5
PDB-V105 数据手册
PHOTONIC Silicon Photodiode, Blue Enhanced Photovoltaic Type PDB-V105 DETECTORS INC. PACKAGE DIMENSIONS INCH [mm] WINDOW CAP (WELDED) 0.030 [0.76] Ø0.325 [8.25] Ø0.250 [6.35] CL 0.168 [4.26] 0.075 [1.91] WIRE BONDS 0.500 [12.70] MIN 45° Ø0.358 [9.09] 78° VIEWING ANGLE CL CL 0.200 [5.08] 0.035 [0.89] CL ANODE Ø0.018 [0.46] CATHODE Ø0.018 [0.46] HEADER PHOTODIODE 0.095 [2.41] SQ 0.086 [2.18] SQ ACTIVE AREA TO-5 HERMETIC CAN PACKAGE ACTIVE AREA = 4.48 mm2 -40 +125 O +240 O TS Soldering Temperature* IL Light Current 0.5 C C C mA 0 .3 0 .2 0 .1 0 *1/16 inch from case for 3 secs max WAVELENGTH (nm) ELECTRO-OPTICAL CHARACTERISTICS (TA=25OC unless otherwise noted) SYMBOL CHARACTERISTIC TEST CONDITIONS MIN TYP ISC Short Circuit Current H = 100 fc, 2850 K ID Dark Current H = 0, VR = 10 V Shunt Resistance H = 0, VR = 10 mV TC RSH RSH Temp. Coefficient CJ Junction Capacitance RSH 30 MAX 200 UNITS mA 50 400 pA 5 GΩ H = 0, VR = 10 mV -8 % / oC H = 0, VR = 0 V** 500 pF 2 λrange Spectral Application Range Spot Scan λp Spectral Response - Peak Spot Scan V BR Breakdown Voltage I = 10 mA N EP Noise Equivalent Power VR = 10 mV @ Peak .5x10-14 Response Time RL = 1 KΩ VR = 0 V 500 tr 1200 Operating Temperature Range 1000 TO % 1100 O 00 800 +150 =1 900 -55 QE 0 .4 600 Storage Temperature 0 .5 700 TSTG 0 .6 400 V 500 75 190 Reverse Voltage SPECTRAL RESPONSE 0 .7 300 ABSOLUTE MAXIMUM RATING (TA=25OC unless otherwise noted) SYMBOL PARAMETER MIN MAX UNITS V BR APPLICATIONS Instrumentation Industrial measurement Exposure sensor Flame monitor DESCRIPTION The PDB-V105 is a silicon, PIN planar diffused, blue enhanced photodiode. Ideal for low noise photovoltaic applications. Packaged in a hermetic TO-5 metal can with a flat window. RESPONSIVITY (A/W) FEATURES Low noise Blue enhanced High shunt resistance High response 350 1100 950 10 nm nm 50 V W/ Hz nS Information in this technical data sheet is believed to be correct and reliable. However, no responsibility is assumed for possible inaccuracies or omission. Specifications are subject to change without notice.**f = 1 MHz [FORM NO. 100-PDB-V105 REV B]
PDB-V105 价格&库存
很抱歉,暂时无法提供与“PDB-V105”相匹配的价格&库存,您可以联系我们找货
