PDB-V104-L
PDB-V104-L
    LUNAOPTOELECTRONICS(Luna Optoelectronics)
    TO-46-2透镜顶部金属罐
    PHOTODIODE BLUE LEN 2.98MM TO-46
PDB-V104-L 数据手册
PHOTONIC Silicon Photodiode, Blue Enhanced Photovoltaic Lens Type PDB-V104-L DETECTORS INC. PACKAGE DIMENSIONS INCH [mm] 0.228 [5.79] 0.150 [3.81] Ø0.184 [4.67] 0.040 [1.02] Ø0.155 [3.94] 0.060 [1.52] 0.500 [12.70] MIN C L 45° C L Ø0.210 [5.33] CL 0.100 [2.54] C L LENS CAP (WELDED) 0.042 [1.06] PHOTODIODE ANODE Ø0.018 [0.46] HEADER CATHODE Ø0.018 [0.46] 0.125 [3.18] 0.066 [1.68] 0.046 [1.17] ACTIVE AREA TO-46 HERMETIC CAN PACKAGE 0.104 [2.64] ACTIVE AREA ACTIVE AREA = 2.98 mm2 DESCRIPTION The PDB-V104-L is a silicon, PIN planar diffused, blue enhanced photodiode. Ideal for low noise photovoltaic applications. Packaged in a hermetic TO-46 metal can with a glass lens cap. Operating Temperature Range -40 +125 O C +240 O C TS Soldering Temperature* IL Light Current 0.5 mA 0.3 0.2 0.1 0 *1/16 inch from case for 3 secs max 1200 C TO 1100 O 900 +150 1000 -55 0.4 800 Storage Temperature % 00 =1 QE 0.5 700 TSTG 0.6 600 V 500 75 400 Reverse Voltage 300 V BR SPECTRAL RESPONSE 0.7 190 ABSOLUTE MAXIMUM RATING (TA=25OC unless otherwise noted) SYMBOL PARAMETER MIN MAX UNITS APPLICATIONS Instrumentation Character recognition Laser detection Industrial controls RESPONSIVITY (A/W) FEATURES Low noise Blue enhanced High shunt resistance High response WAVELENGTH (nm) ELECTRO-OPTICAL CHARACTERISTICS (TA=25 C unless otherwise noted) SYMBOL CHARACTERISTIC TEST CONDITIONS MIN TYP O ISC Short Circuit Current H = 100 fc, 2850 K ID Dark Current H = 0, V R = 10 V RSH Shunt Resistance H = 0, V R = 10 mV TC RSH RSH Temp. Coefficient H = 0, V R = 10 mV CJ Junction Capacitance H = 0, V R = 0 V** λrange Spectral Application Range Spot Scan λp Spectral Response - Peak Spot Scan V BR Breakdown Voltage I = 10 m A N EP tr 35 300 pA 6 GΩ -8 % / oC 340 350 30 UNITS mA 40 150 1.0 MAX pF 1100 nm 950 nm 50 V -14 Noise Equivalent Power V R = 10 mV @ Peak 5x10 Response Time RL = 1 KΩ V R = 0 V 450 W/ Hz nS Information in this technical data sheet is believed to be correct and reliable. However, no responsibility is assumed for possible inaccuracies or omission. Specifications are subject to change without notice. **f = 1 MHz [FORM NO. 100-PDB-V104-L REV N/C]
PDB-V104-L 价格&库存
很抱歉,暂时无法提供与“PDB-V104-L”相匹配的价格&库存,您可以联系我们找货
