PDB-V106
PDB-V106
    LUNAOPTOELECTRONICS(Luna Optoelectronics)
    TO-5
    PHOTODIODE BLUE 10.00MM SQ TO-5
PDB-V106 数据手册
PHOTONIC Silicon Photodiode, Blue Enhanced Photovoltaic Type PDB-V106 DETECTORS INC. PACKAGE DIMENSIONS INCH [mm] Ø0.325 [8.25] WINDOW CAP (WELDED) 0.030 [0.76] Ø0.250 [6.35] 0.168 [4.26] 0.075 [1.91] WIRE BONDS CL 0.500 [12.70] MIN 45° Ø 0.358 [9.09] 55° VIEWING ANGLE CL CL 0.200 [5.08] 0.035 [0.89] CL ANODE Ø0.018 [0.46] CATHODE Ø0.018 [0.46] HEADER PHOTODIODE 0.154 [3.91] SQ Ø0.1404 [Ø3.567] ACTIVE AREA TO-5 HERMETIC CAN PACKAGE ACTIVE AREA = 10.00 mm2 APPLICATIONS Instrumentation Industrial controls Laser detection Flame detection DESCRIPTION The PDB-V106 is a silicon, PIN planar diffused, blue enhanced photodiode. Ideal for low noise photovoltaic applications. Packaged in a hermetic TO-5 metal can with a flat window. Light Current O 500 C mA 0.2 0.1 0 WAVELENGTH (nm) *1/16 inch from case for 3 secs max ELECTRO-OPTICAL CHARACTERISTICS (TA=25OC unless otherwise noted) SYMBOL CHARACTERISTIC TEST CONDITIONS MIN TYP ISC Short Circuit Current H = 100 fc, 2850 K ID Dark Current H = 0, V R = 10 V Shunt Resistance H = 0, V R = 10 mV TC RSH RSH Temp. Coefficient CJ Junction Capacitance RSH λrange λp V BR NEP tr 1200 IL +240 C 0.3 1100 Soldering Temperature* +125 0.4 900 TS -40 O C 1000 Operating Temperature Range O 0% 800 TO +150 0 =1 QE 700 -55 0.5 600 Storage Temperature V 500 TSTG 75 400 Reverse Voltage 0.6 300 V BR SPECTRAL RESPONSE 0.7 190 ABSOLUTE MAXIMUM RATING (TA=25OC unless otherwise noted) SYMBOL PARAMETER MIN MAX UNITS RESPONSIVITY (A/W) FEATURES Low noise Blue enhanced High shunt resistance High response 100 MAX UNITS mA 125 300 500 pA 2 GΩ H = 0, V R = 10 mV -8 % / oC H = 0, V R = 0 V** 1200 pF Spectral Application Range Spot Scan Spectral Response - Peak Spot Scan Breakdown Voltage I = 10 m A .2 350 1100 950 30 nm 50 Noise Equivalent Power VR = 10 mV @ Peak 1.0x10 Response Time RL = 1 KΩ VR = 0 V 800 nm V -14 W/ Hz nS Information in this technical data sheet is believed to be correct and reliable. However, no responsibility is assumed for possible inaccuracies or omission. Specifications are subject to change without notice. **f = 1 MHz [FORM NO. 100-PDB-V106 REV C]
PDB-V106 价格&库存
很抱歉,暂时无法提供与“PDB-V106”相匹配的价格&库存,您可以联系我们找货
