PDB-V115
PDB-V115
    LUNAOPTOELECTRONICS(Luna Optoelectronics)
    TO-5
    PHOTODIODE BLUE 5.07MM SQ TO-5
PDB-V115 数据手册
PHOTONIC Silicon Photodiode, Blue Enhanced Photovoltaic Type PDB-V115 DETECTORS INC. PACKAGE DIMENSIONS INCH [mm] WINDOW CAP (WELDED) Ø0.325 [8.25] Ø0.250 [6.35] 0.168 [4.26] 0.030 [0.76] 0.075 [1.91] CL WIRE BONDS 0.500 [12.70] MIN 45° Ø0.358 [9.09] 73° VIEWING ANGLE CL CL 0.200 [5.08] 0.035 [0.89] CL ANODE Ø0.018 [0.46] CATHODE Ø0.018 [0.46] HEADER PHOTODIODE 0.110 [2.79] SQUARE Ø0.100 [Ø2.54] ACTIVE AREA TO-5 HERMETIC CAN PACKAGE ACTIVE AREA = 5.07 mm2 APPLICATIONS Instrumentation Oximeters Laser sensor Medical sensor DESCRIPTION The PDB-V115 is a silicon, PIN planar diffused, blue enhanced photodiode. Ideal for low noise photovoltaic applications. Packaged in a hermetic TO-5 metal can with a flat window. +125 O +240 O IL Light Current 1.0 C C mA 0 .2 0 .1 0 *1/16 inch from case for 3 secs max WAVELENGTH (nm) ELECTRO-OPTICAL CHARACTERISTICS (TA=25OC unless otherwise noted) SYMBOL CHARACTERISTIC TEST CONDITIONS MIN TYP ISC Short Circuit Current H = 100 fc, 2850 K ID Dark Current H = 0, VR = 10 V Shunt Resistance H = 0, VR = 10 mV TC RSH RSH Temp. Coefficient CJ Junction Capacitance RSH 40 MAX 250 UNITS mA 60 450 pA 5 GΩ H = 0, VR = 10 mV -8 % / oC H = 0, VR = 0 V** 500 pF 2 λrange Spectral Application Range Spot Scan λp Spectral Response - Peak Spot Scan V BR Breakdown Voltage I = 10 mA N EP Noise Equivalent Power VR = 10 mV @ Peak .5x10-14 Response Time RL = 1 KΩ VR = 0 V 500 tr 1200 -40 0 .3 1000 Operating Temperature Range QE 0 .4 % 1100 TO C 00 800 O =1 900 +150 0 .5 600 -55 0 .6 700 Storage Temperature Soldering Temperature* V 400 TSTG TS 75 500 Reverse Voltage 190 V BR SPECTRAL RESPONSE 0 .7 300 ABSOLUTE MAXIMUM RATING (TA=25OC unless otherwise noted) SYMBOL PARAMETER MIN MAX UNITS RESPONSIVITY (A/W) FEATURES Low noise Blue enhanced High shunt resistance High response 350 1100 950 30 nm nm 50 V W/ Hz nS Information in this technical data sheet is believed to be correct and reliable. However, no responsibility is assumed for possible inaccuracies or omission. Specifications are subject to change without notice. **f = 1 MHz [FORM NO. 100-PDB-V115 REV B]
PDB-V115 价格&库存
很抱歉,暂时无法提供与“PDB-V115”相匹配的价格&库存,您可以联系我们找货
