PDB-V140
PDB-V140
    LUNAOPTOELECTRONICS(Luna Optoelectronics)
    2-DIP模块
    Photodiode 950nm 925ns 120° 2-DIP Module
PDB-V140 数据手册
PHOTONIC Silicon Photodiode, Blue Enhanced Photovoltaic Type PDB-V140 DETECTORS INC. PACKAGE DIMENSIONS INCH (mm) 0.370 [9.40] CL 0.185 [4.70] WIRE BONDS 0.070[1.78] + - 0.015 0.38] 1.575 [40.00] ANODE + - 0.015 [0.38] 0.115 [2.92] SOLDER CL + Ø0.430 [10.92] _ CERAMIC 120° VIEWING ANGLE 0.295 [7.49] CATHODE C L 0.124[3.15] REF OPTICAL EPOXY 0.024 [0.61] REF Ø0.020 [ 0.51] SnPb PLATED Cu PIN - 2 PLACES PHOTODIODE 0.150 [3.81] ACTIVE AREA 0.182 [4.62] 0.300 [7.62] ACTIVE AREA 0.322 [8.18] CERAMIC PACKAGE ACTIVE AREA = 29.02 mm2 DESCRIPTION The PDB-V140 is a silicon, PIN planar diffused, blue enhanced photodiode. Ideal for high speed photoconductive applications. Packaged on a two lead ceramic substrate with a clear epoxy glob top. Light Current O 0.5 C mA 0.3 0.2 0.1 0 *1/16 inch from case for 3 secs max WAVELENGTH (nm) ELECTRO-OPTICAL CHARACTERISTICS (TA=25OC unless otherwise noted) SYMBOL CHARACTERISTIC TEST CONDITIONS MIN TYP ISC Short Circuit Current ID Dark Current H = 0, VR = 10 V Shunt Resistance H = 0, VR = 10 mV TC RSH RSH Temp. Coefficient CJ Junction Capacitance RSH H = 100 fc, 2850 K MAX UNITS mA 300 400 50 100 MΩ H = 0, VR = 10 mV -8 % / oC H = 0, VR = 0 V** 3800 pF 2.0 λrange Spectral Application Range Spot Scan λp Spectral Response - Peak Spot Scan V BR Breakdown Voltage I = 10 mA N EP Noise Equivalent Power VR = 10 mV @ Peak 1x10-13 Response Time RL = 1 KΩ VR = 0 V 925 tr 110 0 IL +240 C % 120 0 Soldering Temperature* -40 C 00 900 TS +90 O =1 100 0 Operating Temperature Range O QE 0.4 800 TO +100 0.5 600 -40 0.6 700 Storage Temperature V 400 75 500 TSTG Reverse Voltage 190 V BR SPECTRAL RESPONSE 0.7 300 ABSOLUTE MAXIMUM RATING (TA=25OC unless otherwise noted) SYMBOL PARAMETER MIN MAX UNITS APPLICATIONS Bar code scanner Instrumentation Industrial controls Laser detection RESPONSIVITY (A/W) FEATURES Low noise Blue enhanced High shunt resistance High response 350 1100 950 30 5.0 nA nm nm 50 V W/ Hz nS Information in this technical data sheet is believed to be correct and reliable. However, no responsibility is assumed for possible inaccuracies or omission. Specifications are subject to change without notice. **f = 1 MHz [FORM NO. 100-PDB-V140 REV B]
PDB-V140 价格&库存
很抱歉,暂时无法提供与“PDB-V140”相匹配的价格&库存,您可以联系我们找货
