PDB-V119
PDB-V119
    LUNAOPTOELECTRONICS(Luna Optoelectronics)
    TO-5
    PHOTODIODE BLUE 7.95MM SQ TO-5
PDB-V119 数据手册
PHOTONIC Silicon Photodiode, Blue Enhanced Photovoltaic (OP913WSL Industry Equivalent) Type PDB-V119 DETECTORS INC. PACKAGE DIMENSIONS INCH [mm] WINDOW CAP (WELDED) Ø0.325 [8.25] Ø0.250 [6.35] 0.168 [4.26] 0.030 [0.76] C L 0.075 [1.91] WIRE BONDS 0.500 [12.70] MIN 45° CL Ø0.358 [9.09] CL 68° VIEWING ANGLE 0.200 [5.08] 0.035 [0.89] C L ANODE Ø0.018 [0.46] HEADER CATHODE Ø0.018 [0.46] PHOTODIODE 0.125 [3.175] SQ 0.113 [2.87] SQ ACTIVE AREA TO-5 HERMETIC CAN PACKAGE ACTIVE AREA = 7.95 mm2 DESCRIPTION The PDB-V119 is a silicon, PIN planar diffused, blue enhanced photodiode. Ideal for low noise photovoltaic applications. Packaged in a hermetic TO-5 metal can with a glass window cap. -40 +125 O TS Soldering Temperature* +240 O IL Light Current C C mA 0.3 0.2 0.1 0 WAVELENGTH (nm) *1/16 inch from case for 3 secs max ELECTRO-OPTICAL CHARACTERISTICS (TA=25OC unless otherwise noted) SYMBOL CHARACTERISTIC TEST CONDITIONS MIN TYP ISC Short Circuit Current H = 100 fc, 2850 K ID Dark Current H = 0, V R = 10 mV Shunt Resistance H = 0, V R = 10 mV TC RSH RSH Temp. Coefficient CJ Junction Capacitance RSH λrange λp V BR NEP tr 60 MAX UNITS mA 80 10 50 nA 1 GΩ H = 0, V R = 10 mV -8 % / oC H = 0, V R = 0 V** 800 Spectral Application Range Spot Scan Spectral Response - Peak Spot Scan Breakdown Voltage I = 10 m A Noise Equivalent Power VR = 10 V @ Peak Response Time RL = 1 KΩ VR = 0 V .2 350 5 1200 Operating Temperature Range 0.4 1100 TO C 900 O 1000 +150 800 -55 700 Storage Temperature % 00 =1 E Q 0.5 600 TSTG 500 V 500 75 400 Reverse Voltage 0.6 300 V BR SPECTRAL RESPONSE 0.7 190 ABSOLUTE MAXIMUM RATING (TA=25OC unless otherwise noted) SYMBOL PARAMETER MIN MAX UNITS APPLICATIONS Bar code detector Encoder sensor Laser detection Instrumentation RESPONSIVITY (A/W) FEATURES Wide view angle Low noise Large active area High shunt resistance 1000 pF 1100 nm 950 nm 10 V -14 5x10 750 W/ Hz nS Information in this technical data sheet is believed to be correct and reliable. However, no responsibility is assumed for possible inaccuracies or omission. Specifications are subject to change without notice.** f = 1 MHz [FORM NO. 100-PDB-V119 REV A]
PDB-V119 价格&库存
很抱歉,暂时无法提供与“PDB-V119”相匹配的价格&库存,您可以联系我们找货
