PDB-V108
PDB-V108
    LUNAOPTOELECTRONICS(Luna Optoelectronics)
    TO8-3
    PHOTODIODE BLUE 31.00MM SQ TO-8
PDB-V108 数据手册
PHOTONIC Silicon Photodiode, Blue Enhanced Photovoltaic Type PDB-V108 DETECTORS INC. PACKAGE DIMENSIONS INCH [mm] 0.215 [5.46] Ø0.483 [12.27] 0.065 [1.65] Ø0.449 [11.39] 1.500 [38.10] WIRE BONDS CL 69° VIEWING ANGLE Ø0.550 [13.97] ANODE Ø0.018 [0.46] 0.295 [7.49] CL CATHODE Ø0.018 [0.46] HEADER PHOTODIODE WINDOW CAP (WELDED) 0.265 [6.74] SQUARE 0.2472 [6.289] ACTIVE AREA TO-8 HERMETIC PACKAGE ACTIVE AREA = 31.00 mm2 DESCRIPTION The PDB-V108 is a silicon, PIN planar diffused, blue enhanced photodiode. Ideal for low noise photovoltaic applications. Packaged in a hermetic TO-8 metal can with a flat window. O +240 O Soldering Temperature* IL Light Current 500 C C mA 0.3 0.2 0.1 0 *1/16 inch from case for 3 secs max WAVELENGTH (nm) ELECTRO-OPTICAL CHARACTERISTICS (TA=25OC unless otherwise noted) SYMBOL CHARACTERISTIC TEST CONDITIONS MIN TYP ISC Short Circuit Current H = 100 fc, 2850 K ID Dark Current H = 0, VR = 10 V Shunt Resistance H = 0, V R = 10 mV TC RSH RSH Temp. Coefficient H = 0, V R = 10 mV CJ Junction Capacitance H = 0, V R = 0 V** RSH λrange λp V BR NEP tr 1200 +125 1100 -40 0.4 1000 Operating Temperature Range C 900 O 800 +150 700 -55 % 00 =1 E Q 0.5 600 Storage Temperature TS V 500 TSTG TO 75 400 Reverse Voltage 0.6 300 V BR SPECTRAL RESPONSE 0.7 190 ABSOLUTE MAXIMUM RATING (TA=25OC unless otherwise noted) SYMBOL PARAMETER MIN MAX UNITS APPLICATIONS Laser sensor Instrumentation Industrial controls Colorimetry RESPONSIVITY (A/W) FEATURES Low noise Blue enhanced High shunt resistance High response Spectral Application Range Spot Scan Spectral Response - Peak Spot Scan Breakdown Voltage I = 10 m A 375 800 pA 1 GΩ -8 % / oC 2500 pF 350 30 UNITS mA 430 250 .2 MAX 1100 nm 950 nm 40 V -14 Noise Equivalent Power VR = 10 mV @ Peak 5x10 Response Time RL = 1 KΩ VR = 0 V 950 W/ Hz nS Information in this technical data sheet is believed to be correct and reliable. However, no responsibility is assumed for possible inaccuracies or omission. Specifications are subject to change without notice.**f = 1 MHz [FORM NO. 100-PDB-V108 REV C]
PDB-V108 价格&库存
很抱歉,暂时无法提供与“PDB-V108”相匹配的价格&库存,您可以联系我们找货
