PDB-V109
PDB-V109
    LUNAOPTOELECTRONICS(Luna Optoelectronics)
    TO8-3
    PHOTODIODE BLUE 42.86MM SQ TO-8
PDB-V109 数据手册
PHOTONIC Silicon Photodiode, Blue Enhanced Photovoltaic Type PDB-V109 DETECTORS INC. PACKAGE DIMENSIONS INCH [mm] Ø0.483 [12.27] Ø0.449 [11.39] 0.215 [5.46] 0.065 [1.65] WIRE BONDS 1.50 [38.1] C L 79° VIEWING ANGLE Ø0.550 [13.97] 0.295 [7.49] ANODE Ø0.018 [0.46] CL CATHODE Ø0.018 [0.46] HEADER WINDOW CAP (WELDED) PHOTODIODE 0.340 [8.64] 0.230 [5.84] 0.209 [5.31] ACTIVE AREA TO-8 HERMETIC PACKAGE 0.319 [8.10] ACTIVE AREA ACTIVE AREA = 42.86 mm2 DESCRIPTION The PDB-V109 is a silicon, PIN planar diffused, blue enhanced photodiode. Ideal for low noise photovoltaic applications. Packaged in a hermetic TO-8 metal can with a flat window. Light Current O 0.5 C mA 0.3 0.2 0.1 0 *1/16 inch from case for 3 secs max WAVELENGTH (nm) ELECTRO-OPTICAL CHARACTERISTICS (TA=25OC unless otherwise noted) SYMBOL CHARACTERISTIC TEST CONDITIONS MIN TYP ISC Short Circuit Current ID Dark Current H = 0, VR = 10 mV Shunt Resistance H = 0, VR = 10 mV TC RSH RSH Temp. Coefficient CJ Junction Capacitance RSH H = 100 fc, 2850 K MAX UNITS mA 405 500 50 150 MΩ H = 0, VR = 10 mV -8 % / oC H = 0, VR = 0 V** 4,500 pF 66 λrange Spectral Application Range Spot Scan λp Spectral Response - Peak Spot Scan V BR Breakdown Voltage I = 10 mA N EP Noise Equivalent Power VR = 10 mV @ Peak 1.0x10-14 Response Time RL = 1 KΩ VR = 0 V 1,000 tr 1200 IL +240 C % 1100 Soldering Temperature* +125 C 00 900 TS -40 O =1 1000 Operating Temperature Range O QE 0.4 700 TO +150 0.5 800 -55 0.6 500 Storage Temperature V 600 75 400 TSTG Reverse Voltage 190 V BR SPECTRAL RESPONSE 0.7 300 ABSOLUTE MAXIMUM RATING (TA=25OC unless otherwise noted) SYMBOL PARAMETER MIN MAX UNITS APPLICATIONS Instrumentation Industrial controls Photoelectric switches Encoder sensors RESPONSIVITY (A/W) FEATURES Low noise Blue enhanced High shunt resistance High response 350 1100 950 20 200 pA nm nm 30 V W/ Hz nS Information in this technical data sheet is believed to be correct and reliable. However, no responsibility is assumed for possible inaccuracies or omission. Specifications are subject to change without notice.**f = 1 MHz [FORM NO. 100-PDB-V109 REV B]
PDB-V109 价格&库存
很抱歉,暂时无法提供与“PDB-V109”相匹配的价格&库存,您可以联系我们找货
