PDB-C202
PDB-C202
    LUNAOPTOELECTRONICS(Luna Optoelectronics)
    TO8-3
    PHOTODIODE BI-CELL 15.5MM SQ TO8
PDB-C202 数据手册
PHOTONIC Silicon Photodiode, Blue Enhanced Photoconductive Bi-cell Type PDB-C202 DETECTORS INC. PACKAGE DIMENSIONS INCH [mm] 0.215 [5.46] 0.065 [1.65] Ø0.483 [12.27] Ø0.449 [11.39] 1.50 [38.1] WIRE BONDS ANODE #1 Ø0.018 [0.46] CL Ø0.295 [7.49] 69° VIEWING ANGLE Ø0.550 [13.97] CATHODE & CASE Ø0.018 [0.46] CL ANODE #2 Ø0.018 [0.46] HEADER WINDOW CAP (WELDED) PHOTODIODE 0.261 [6.63] SQUARE R0.1235 [R3.137] ACTIVE AREA 2 PLACES TO-8 HERMETIC PACKAGE 0.0018 [0.045] GAP ACTIVE AREA = 15.50 mm2 PER ELEMENT DESCRIPTION The PDB-C202 is a silicon, pin planar diffused, blue enhanced bi-cell photodiode. Ideal for high speed photoconductive applications. Packaged in a hermetic TO-8 metal can with a flat window. Light Current O 0.5 C mA 0.3 0.2 0.1 0 *1/16 inch from case for 3 secs max WAVELENGTH (nm) ELECTRO-OPTICAL CHARACTERISTICS (TA=25OC unless otherwise noted) SYMBOL CHARACTERISTIC TEST CONDITIONS MIN TYP ISC Short Circuit Current ID Dark Current H = 0, VR = 10 V Shunt Resistance H = 0, VR = 10 mV TC RSH RSH Temp. Coefficient CJ Junction Capacitance RSH H = 100 fc, 2850 K MAX UNITS mA 200 250 75 100 MΩ H = 0, VR = 10 mV -8 % / oC H = 0, VR = 10 V 75 pF λrange Spectral Application Range Spot Scan λp Spectral Response - Peak Spot Scan V BR Breakdown Voltage I = 10 mA N EP Noise Equivalent Power VR = 10 V @ Peak Response Time RL = 1 KΩ VR = 10 V tr 1200 IL +240 C % 1100 Soldering Temperature* +125 C 00 900 TS -40 O =1 1000 Operating Temperature Range O QE 0.4 700 TO +150 0.5 800 -55 0.6 500 Storage Temperature V 600 100 400 TSTG Reverse Voltage 190 V BR SPECTRAL RESPONSE 0.7 300 ABSOLUTE MAXIMUM RATING (TA=25OC unless otherwise noted) SYMBOL PARAMETER MIN MAX UNITS APPLICATIONS Optical alignment Position sensing Edge sensing Instrumentation RESPONSIVITY (A/W) FEATURES High speed Low capacitance Blue enhanced Low dark current 5 350 10 1100 950 50 nA nm nm 100 V 1.5x10-14 10 W/ 30 Hz nS Information in this technical data sheet is believed to be correct and reliable. However, no responsibility is assumed for possible inaccuracies or omission. Specifications are subject to change without notice. [FORM NO. 100-PDB-C202 REV A]
PDB-C202 价格&库存
很抱歉,暂时无法提供与“PDB-C202”相匹配的价格&库存,您可以联系我们找货
