PDI-V108-F
PDI-V108-F
    LUNAOPTOELECTRONICS(Luna Optoelectronics)
    TO8-3
    PHOTODIODE IR 31.00MM SQ TO-8
PDI-V108-F 数据手册
PHOTONIC DETECTORS INC. Silicon Photodiode, Near I.R. Photovoltaic Type PDI-V108-F PACKAGE DIMENSIONS INCH [mm] 0.215 [5.46] Ø0.483 [12.27] 0.065 [1.65] Ø0.449 [11.39] 1.500 [38.10] WIRE BONDS CL 69° VIEWING ANGLE Ø0.550 [13.97] ANODE Ø0.018 [0.46] 0.295 [7.49] CL CATHODE Ø0.018 [0.46] PHOTODIODE HEADER I.R. PASS FILTER WINDOW CAP (WELDED) 0.265 [6.74] SQUARE 0.2472 [6.289] ACTIVE AREA TO-8 HERMETIC CAN PACKAGE ACTIVE AREA = 31.00 mm2 +240 O Soldering Temperature* IL Light Current 500 C C mA 0.3 0.2 0.1 0 WAVELENGTH (nm) *1/16 inch from case for 3 secs max ELECTRO-OPTICAL CHARACTERISTICS (TA=25OC unless otherwise noted) SYMBOL CHARACTERISTIC TEST CONDITIONS MIN TYP ISC Short Circuit Current H = 100 fc, 2850 K ID Dark Current H = 0, V R = 10 V Shunt Resistance H = 0, V R = 10 mV TC RSH RSH Temp. Coefficient CJ Junction Capacitance RSH λrange λp V BR NEP tr 1200 O 1100 +80 900 -40 0.4 1000 Operating Temperature Range C 800 O 700 +100 % 00 =1 E Q 0.5 600 -55 0.6 500 Storage Temperature TS V 400 TSTG TO 100 300 Reverse Voltage 190 V BR SPECTRAL RESPONSE 0.7 RESPONSIVITY (A/W) DESCRIPTION The PDI-V108-F is a silicon, PIN planar I.R. pass visible rejection diffused photodiode with NIR pass, visible Match to I.R. emitters light rejection optical filter. Ideal for low noise photovoltaic NIR applications. PackHermetic package aged in a hermetic TO-8 metal can with a flat window cap. ABSOLUTE MAXIMUM RATING (TA=25OC unless otherwise noted) SYMBOL PARAMETER MIN MAX UNITS APPLICATIONS I.R. detector I.R. laser detector Photo-interrupters Industrial controls FEATURES Low noise 338 MAX mA 387 250 UNITS 800 pA 1 GΩ H = 0, V R = 10 mV -8 % / oC H = 0, V R = 0 V** 2500 pF Spectral Application Range Spot Scan Spectral Response - Peak Spot Scan Breakdown Voltage I = 10 m A Noise Equivalent Power VR = 10 mV @ Peak Response Time RL = 1 KΩ VR = 0 V .2 700 30 1100 nm 950 nm 40 V -14 5x10 950 W/ Hz nS Information in this technical data sheet is believed to be correct and reliable. However, no responsibility is assumed for possible inaccuracies or omission. Specifications are subject to change without notice. ** f = 1 MHz [FORM NO. 100-PDI-V108-F REV A]
PDI-V108-F 价格&库存
很抱歉,暂时无法提供与“PDI-V108-F”相匹配的价格&库存,您可以联系我们找货
