PDI-V119-F
PDI-V119-F
    LUNAOPTOELECTRONICS(Luna Optoelectronics)
    TO-5
    PHOTODIODE IR 7.95MM SQ TO-5
PDI-V119-F 数据手册
PHOTONIC DETECTORS INC. Silicon Photodiode, Near I.R. Photovoltaic Type PDI-V119-F PACKAGE DIMENSIONS INCH [mm] WINDOW CAP (WELDED) 0.030 [0.76] Ø0.325 [8.25] Ø0.250 [6.35] CL 0.168 [4.26] 0.075 [1.91] WIRE BONDS 0.500 [12.70] MIN 45° Ø0.358 [9.09] 78° VIEWING ANGLE CL 0.035 [0.89] C L ANODE Ø0.018 [0.46] CATHODE Ø0.018 [0.46] I.R. PASS FILTER HEADER PHOTODIODE CL 0.200 [5.08] 0.125 [3.18] 0.113 [2.87] ACTIVE AREA TO-5 HERMETIC CAN PACKAGE 0.113 [2.87] ACTIVE AREA ACTIVE AREA = 7.95 mm2 -40 +80 O C +240 O C TS Soldering Temperature* IL Light Current 0.5 mA 0.3 0.2 0.1 0 *1/16 inch from case for 3 secs max WAVELENGTH (nm) ELECTRO-OPTICAL CHARACTERISTICS (TA=25 C unless otherwise noted) SYMBOL CHARACTERISTIC TEST CONDITIONS MIN TYP O ISC Short Circuit Current H = 100 fc, 2850 K ID Dark Current H = 0, V R = 10 V Shunt Resistance H = 0, V R = 10 mV TC RSH RSH RSH Temp. Coefficient H = 0, V R = 10 mV CJ Junction Capacitance H = 0, V R = 0 V** λrange Spectral Application Range Spot Scan λp Spectral Response - Peak Spot Scan V BR Breakdown Voltage I = 10 m A N EP tr Noise Equivalent Power V R = 10 V @ Peak Response Time RL = 1 KΩ V R = 0 V 54 50 nA 1 GΩ -8 % / oC 800 700 5 UNITS mA 72 10 .2 MAX 1000 pF 1100 nm 950 nm 10 V 5x10 -14 750 W/ Hz nS Information in this technical data sheet is believed to be correct and reliable. However, no responsibility is assumed for possible inaccuracies or omission. Specifications are subject to change without notice. ** f = 1 MHz 1200 Operating Temperature Range 1100 C TO 900 O 0% 10 1000 +100 = 800 -55 QE 0.4 700 Storage Temperature 0.5 600 TSTG 0.6 500 V 400 100 300 Reverse Voltage 190 V BR SPECTRAL RESPONSE 0.7 RESPONSIVITY (A/W) DESCRIPTION The PDI-C119-F is a silicon, PIN planar I.R. pass visible rejection diffused photodiode with NIR pass, visible Match to I.R. emitters light rejection optical filter. Ideal for low noise photovoltaic NIR applications. PackHermetic package aged in a hermetic TO-5 metal can with a flat window cap. ABSOLUTE MAXIMUM RATING (TA=25OC unless otherwise noted) SYMBOL PARAMETER MIN MAX UNITS APPLICATIONS I.R. detector I.R. laser detector Photo-interrupters Industrial controls FEATURES Low noise
PDI-V119-F 价格&库存
很抱歉,暂时无法提供与“PDI-V119-F”相匹配的价格&库存,您可以联系我们找货
