PHOTONIC
DETECTORS INC.
Silicon Photodiode, Near I.R. Photovoltaic
Type PDI-V109-F
PACKAGE DIMENSIONS INCH [mm]
Ø0.483 [12.27]
Ø0.449 [11.39]
0.215 [5.46]
0.065 [1.65]
WIRE
BONDS
1.50 [38.1]
C
L
79°
VIEWING
ANGLE
Ø0.550
[13.97]
PHOTODIODE
0.295 [7.49]
ANODE
Ø0.018 [0.46]
CL
CATHODE
Ø0.018 [0.46]
HEADER
WINDOW CAP
(WELDED)
I.R. PASS FILTER
0.340 [8.64]
0.230 [5.84]
0.209 [5.31] ACTIVE AREA
TO-8 HERMETIC CAN PACKAGE
0.319 [8.10] ACTIVE AREA
ACTIVE AREA = 42.86 mm2
-40
+80
O
C
+240
O
C
TS
Soldering Temperature*
IL
Light Current
1.0
mA
0.3
0.2
0.1
*1/16 inch from case for 3 secs max
1200
Operating Temperature Range
1100
C
TO
900
O
0%
10
1000
+100
800
-55
QE
0.4
700
Storage Temperature
0.5
600
TSTG
0.6
500
V
400
100
300
Reverse Voltage
190
V BR
SPECTRAL RESPONSE
0.7
RESPONSIVITY (A/W)
DESCRIPTION
The PDI-V109-F is a silicon, PIN planar
I.R. pass visible rejection diffused photodiode with NIR pass, visible
Match to I.R. emitters light rejection optical filter. Ideal for low
noise photovoltaic NIR applications. PackHermetic package
aged in a hermetic TO-8 metal can with a
flat window cap.
ABSOLUTE MAXIMUM RATING (TA=25OC unless otherwise noted)
SYMBOL
PARAMETER
MIN
MAX
UNITS
APPLICATIONS
I.R. detector
I.R. laser detector
Photo-interrupters
Industrial controls
FEATURES
Low noise
WAVELENGTH (nm)
ELECTRO-OPTICAL CHARACTERISTICS (TA=25 C unless otherwise noted)
SYMBOL CHARACTERISTIC
TEST CONDITIONS
MIN
TYP
O
ISC
Short Circuit Current
H = 100 fc, 2850 K
ID
Dark Current
H = 0, V R = 10 mV
Shunt Resistance
H = 0, V R = 10 mV
TC RSH
RSH
RSH Temp. Coefficient
H = 0, V R = 10 mV
CJ
Junction Capacitance
H = 0, V R = 0 V**
λrange
Spectral Application Range Spot Scan
λp
Spectral Response - Peak
Spot Scan
V BR
Breakdown Voltage
I = 10 m A
N EP
tr
Noise Equivalent Power
VR = 10 mV @ Peak
Response Time
RL = 1 KΩ V R = 0 V
365
200
pA
150
MΩ
-8
% / oC
4,500
700
pF
1100
950
UNITS
mA
405
66
50
MAX
nm
nm
30
V
-14
1.0x10
1000
W/
Hz
nS
Information in this technical data sheet is believed to be correct and reliable. However, no responsibility is assumed for possible inaccuracies or omission. Specifications
are subject to change without notice. ** f = 1 MHz
很抱歉,暂时无法提供与“PDI-V109-F”相匹配的价格&库存,您可以联系我们找货
