PDB-V119-L
PDB-V119-L
    LUNAOPTOELECTRONICS(Luna Optoelectronics)
    TO-5
    PHOTODIODE BLUE LEN 7.95MM TO-5
PDB-V119-L 数据手册
PHOTONIC Silicon Photodiode, Blue Enhanced Photovoltaic DETECTORS INC. (OP913WSL Industry Equivalent) Lens Type PDB-V119L PACKAGE DIMENSIONS INCH [mm] LENS CAP (WELDED) Ø0.325 [8.25] Ø0.250 [6.35] 0.030 [0.76] WIRE CL 20° BONDS VIEWING 45° ANGLE 0.075 [1.91] 0.500 [12.70] MIN CL Ø0.358 [9.09] CL 0.200 [5.08] 0.035 [0.89] HEADER PHOTODIODE 0.125 [3.175] SQ 0.113 [2.87] SQ ACTIVE AREA CL ANODE Ø0.018 [0.46] CATHODE Ø0.018 [0.46] 0.260 [6.60] 0.348 [8.84] TO-5 HERMETIC LENS CAN PACKAGE ACTIVE AREA = 7.95 mm2 DESCRIPTION The PDB-V119L is a silicon, PIN planar diffused, blue enhanced photodiode. Ideal for low noise photovoltaic applications. Packaged in a hermetic TO-5 metal can with a glass lens window cap. Operating Temperature Range -40 +125 O C +240 O C TS Soldering Temperature* IL Light Current 0.5 mA 0.3 0.2 0.1 0 *1/16 inch from case for 3 secs max 1200 C TO 1100 O 900 +150 % 00 =1 1000 -55 QE 0.4 800 Storage Temperature 0.5 700 TSTG 0.6 600 V 500 75 400 Reverse Voltage 300 V BR SPECTRAL RESPONSE 0.7 190 ABSOLUTE MAXIMUM RATING (TA=25OC unless otherwise noted) SYMBOL PARAMETER MIN MAX UNITS APPLICATIONS Bar code detector Encoder sensor Laser detection Instrumentation RESPONSIVITY (A/W) FEATURES Narrow angle High speed Large active area Low dark current WAVELENGTH (nm) ELECTRO-OPTICAL CHARACTERISTICS (TA=25 C unless otherwise noted) SYMBOL CHARACTERISTIC TEST CONDITIONS MIN TYP O ISC Short Circuit Current H = 100 fc, 2850 K ID Dark Current H = 0, V R = 10 mV Shunt Resistance H = 0, V R = 10 mV TC RSH RSH RSH Temp. Coefficient H = 0, V R = 10 mV CJ Junction Capacitance H = 0, V R = 0 V** λrange Spectral Application Range Spot Scan λp Spectral Response - Peak Spot Scan V BR Breakdown Voltage I = 10 m A N EP tr Noise Equivalent Power V R = 10 V @ Peak Response Time RL = 1 KΩ V R = 0 V 60 50 pA 1 GΩ -8 % / oC 800 350 5 UNITS mA 80 10 .2 MAX 1000 pF 1100 nm 950 nm 10 V 9x10 -15 750 W/ Hz nS Information in this technical data sheet is believed to be correct and reliable. However, no responsibility is assumed for possible inaccuracies or omission. Specifications are subject to change without notice.** f = 1 MHz [FORM NO. 100-PDB-V119L REV A]
PDB-V119-L 价格&库存
很抱歉,暂时无法提供与“PDB-V119-L”相匹配的价格&库存,您可以联系我们找货
