PDB-C207
PDB-C207
    LUNAOPTOELECTRONICS(Luna Optoelectronics)
    TO-46-2,金属罐
    PHOTODIODE QUAD 0.33MM SQ TO-46
PDB-C207 数据手册
PHOTONIC Silicon Photodiode, Blue Enhanced Photoconductive Quadrant Type PDB-C207 DETECTORS INC. PACKAGE DIMENSIONS INCH [mm] Ø0.213 [5.41] 0.142 [3.61] 0.063 [1.60] CHIP SURFACE 0.510 [13.0] MIN 0.039 [0.99] Ø0.118 [3.00] CATHODE ANODE 4 PLCS Ø0.185 [4.70] 49° Ø0.013 [0.33] 5 PLACES Ø0.100 [Ø2.54] 0.059 [1.50] SQ 0.023 [0.58] SQ ACTIVE AREA 4 PLACES TO-46 HERMETIC PACKAGE 0.0008 [0.020] GAP TYP ACTIVE AREA = 0.33 mm2 PER ELEMENT DESCRIPTION The PDB-C207 is a silicon, pin planar diffused, blue enhanced quadrant photodiode. Ideal for high speed photoconductive applications. Packaged in a hermetic TO-46 metal can with a flat window. Light Current O 0.5 C mA 0.3 0.2 0.1 0 *1/16 inch from case for 3 secs max WAVELENGTH (nm) ELECTRO-OPTICAL CHARACTERISTICS (TA=25OC unless otherwise noted) SYMBOL CHARACTERISTIC TEST CONDITIONS MIN TYP ISC Short Circuit Current ID Dark Current H = 0, VR = 1 V Shunt Resistance H = 0, VR = 10 mV TC RSH RSH Temp. Coefficient CJ Junction Capacitance RSH H = 100 fc, 2850 K MAX UNITS mA 1.5 2.2 100 500 MΩ H = 0, VR = 10 mV -8 % / oC H = 0, VR = 10 V 10 pF λrange Spectral Application Range Spot Scan λp Spectral Response - Peak Spot Scan V BR Breakdown Voltage I = 10 mA N EP Noise Equivalent Power VR = 10 V @ Peak Response Time RL = 1 KΩ VR = 10 V tr 1200 IL +240 C % 1100 Soldering Temperature* -20 C 00 900 TS +80 O =1 1000 Operating Temperature Range O QE 0.4 700 TO +100 0.5 800 -30 0.6 500 Storage Temperature V 600 100 400 TSTG Reverse Voltage 190 V BR SPECTRAL RESPONSE 0.7 300 ABSOLUTE MAXIMUM RATING (TA=25OC unless otherwise noted) SYMBOL PARAMETER MIN MAX UNITS APPLICATIONS Optical alignment Position sensing Edge sensing Instrumentation RESPONSIVITY (A/W) FEATURES High speed Low capacitance Blue enhanced Low dark current 1 350 1100 950 30 5 nA nm nm 75 6x10-13 100 V W/ Hz nS Information in this technical data sheet is believed to be correct and reliable. However, no responsibility is assumed for possible inaccuracies or omission. Specifications are subject to change without notice. [FORM NO. 100-PDB-C207 REV A]
PDB-C207 价格&库存
很抱歉,暂时无法提供与“PDB-C207”相匹配的价格&库存,您可以联系我们找货
