PDB-C206
PDB-C206
    LUNAOPTOELECTRONICS(Luna Optoelectronics)
    PCB安装
    PHOTODIODE QUAD 11.33MM SQ PCB
PDB-C206 数据手册
PHOTONIC Silicon Photodiode, Blue Enhanced Photoconductive Quadrant Type PDB-C206 DETECTORS INC. PACKAGE DIMENSIONS INCH [mm] 0.625 [15.88] SQ 4X Ø0.078 HOLE CL CL 0.100 [2.54] WIRE BONDS 0.062 [1.57] 0.075 [1.91] P.W.B. 0.100 [2.54] CL 0.212 [5.40] CL 0.050 [1.27] TYP CL PDI 0.425 [10.79] 0.100 [25.4] MAX CL 0.425 [10.79] CATHODE 4X ANODE CHIP ACRYLIC CONFORMAL COATING CL WIRE BOND POTTING 0.1325 [3.366] SQ ACTIVE AREA 4 PLACES 5X Ø0.028 HOLES P.C.B. CHIP ON BOARD PACKAGE 0.010 [0.25] GAP TYP ACTIVE AREA = 11.33 mm2 PER ELEMENT DESCRIPTION The PDB-C206 is a silicon, pin planar diffused, blue enhanced large area quadrant photodiode. Each element is 11.33 mm2 with a .010 inch (0.25 mm) gap. Packaged on a .062 inch thick P.C.B. chip on board. Light Current O 0.5 C mA 0.3 0.2 0.1 0 1200 IL +240 C % 1100 Soldering Temperature* +100 C 00 900 TS -40 O =1 1000 Operating Temperature Range O QE 0.4 700 TO +125 0.5 800 -50 0.6 500 Storage Temperature V 600 100 400 TSTG Reverse Voltage 190 V BR SPECTRAL RESPONSE 0.7 300 ABSOLUTE MAXIMUM RATING (TA=25OC unless otherwise noted) SYMBOL PARAMETER MIN MAX UNITS APPLICATIONS Optical alignment Position sensing Edge sensing Instrumentation RESPONSIVITY (A/W) FEATURES Narrow gap P.C.B. mount Blue enhanced Large active area WAVELENGTH (nm) ELECTRO-OPTICAL CHARACTERISTICS (TA=25OC unless otherwise noted) SYMBOL CHARACTERISTIC TEST CONDITIONS MIN TYP ISC Short Circuit Current ID Dark Current H = 0, VR = 10 V Shunt Resistance H = 0, VR = 10 mV TC RSH RSH Temp. Coefficient CJ Junction Capacitance RSH H = 100 fc, 2850 K UNITS mA 185 50 100 MΩ H = 0, VR = 10 mV -8 % / oC H = 0, VR = 10 V 50 pF λrange Spectral Application Range Spot Scan λp Spectral Response - Peak Spot Scan V BR Breakdown Voltage I = 10 mA N EP Noise Equivalent Power VR = 10 V @ Peak Response Time RL = 1 KΩ VR = 10 V tr MAX 100 10 350 1100 950 50 50 nA nm nm 75 1.0x10-14 25 V W/ Hz nS Information in this technical data sheet is believed to be correct and reliable. However, no responsibility is assumed for possible inaccuracies or omission. Specifications are subject to change without notice. [FORM NO. 100-PDB-C206 REV A]
PDB-C206 价格&库存
很抱歉,暂时无法提供与“PDB-C206”相匹配的价格&库存,您可以联系我们找货
