PDB-C204
PDB-C204
    LUNAOPTOELECTRONICS(Luna Optoelectronics)
    TO8-3
    PHOTODIODE QUAD 7.75MM SQ TO-8
PDB-C204 数据手册
PHOTONIC Silicon Photodiode, Blue Enhanced Photoconductive Quadrant Type PDB-C204 DETECTORS INC. PACKAGE DIMENSIONS INCH (mm) 0.182 [4.62] Ø0.550 [13.97] Ø0.475 [12.07] 0.032 [0.81] 0.075 [1.91] WINDOW CAP 0.032 [0.81] 0.500 [12.70] MIN C L Ø0.600 [15.24] 45° 4 0.100 [2.54] 1 3 2 Ø0.400 [10.16] ANODE #1 94° VIEWING ANGLE C L WIRE BONDS ANODE #3 CATHODE & CASE ANODE #4 ALL LEADS ARE Ø0.015 [0.38] CHIP 0.200 [5.08] HEADER 0.260 [6.60] SQUARE R0.1235 [R3.137] 0.600 DIA TO-8 CAN PACKAGE 0.0018 [0.045] TYP GAP ACTIVE AREA = 7.75 mm2 PER ELEMENT +125 O C +240 O C Soldering Temperature* IL Light Current 0.5 mA 0.3 0.2 0.1 0 WAVELENGTH (nm) *1/16 inch from case for 3 secs max ELECTRO-OPTICAL CHARACTERISTICS PER ELEMENT (TA=25OC unless otherwise noted) SYMBOL CHARACTERISTIC TEST CONDITIONS MIN TYP MAX UNITS ISC Short Circuit Current H = 100 fc, 2850 K ID Dark Current H = 0, V R = 10 V Shunt Resistance H = 0, V R = 10 mV TC RSH RSH RSH Temp. Coefficient H = 0, V R = 10 mV CJ Junction Capacitance H = 0, V R = 10 V λrange Spectral Application Range Spot Scan λp Spectral Response - Peak Spot Scan V BR Breakdown Voltage I = 10 m A N EP tr Noise Equivalent Power V R = 10 V @ Peak Response Time RL = 1 KΩ V R = 10 V 100 mA 125 2.5 150 5 200 MΩ -8 % / oC 40 pF 320 1100 950 50 nA nm 100 V -14 .75x10 5 nm W/ 15 Hz nS Information in this technical data sheet is believed to be correct and reliable. However, no responsibility is assumed for possible inaccuracies or omission. Specifications are subject to change without notice. 1200 -40 1100 Operating Temperature Range 0.4 0% 10 900 C = 1000 O QE 800 +150 0.5 700 -55 0.6 600 Storage Temperature TS V 500 TSTG TO 100 0.7 400 Reverse Voltage SPECTRAL RESPONSE 300 V BR APPLICATIONS Optical Alignment Position sensing Edge sensing Instrumentation 190 DESCRIPTION The PDB-C204 is a silicon, pin planar diffused, blue enhanced quadrant cell photodiode. Ideal for high speed photoconductive applications. Packaged in a 0.600 dia TO-8 metal can with a flat window cap. ABSOLUTE MAXIMUM RATING (TA=25OC unless otherwise noted) SYMBOL PARAMETER MIN MAX UNITS RESPONSIVITY (A/W) FEATURES High speed Low capacitance Blue enhanced Low dark current
PDB-C204 价格&库存
很抱歉,暂时无法提供与“PDB-C204”相匹配的价格&库存,您可以联系我们找货
