PDB-C208
PDB-C208
    LUNAOPTOELECTRONICS(Luna Optoelectronics)
    阵列-8元件
    PHOTODIODE QUAD 2.31MM SQ PCB
PDB-C208 数据手册
PHOTONIC DETECTORS INC. Silicon Photodiode Array, Photoconductive 8 element Type PDB-C208 PACKAGE DIMENSIONS INCH (mm) .600 [15.24] CL C L .062 [1.57] CL .100 [2.54] .014 [0.36] GAP (BETWEEN ACTIVE AREA) P.W.B 1 PHOTODIODE ARRAY CHIP (ACTIVE AREA) 2 3 4 5 CL .0785 [1.99] 1 2 3 4 5 6 7 PIN CONNECTIONS ELEMENT NO. PIN NO. 1 6 2 1 3 7 4 2 5 9 6 4 7 10 8 5 CATHODE 3 CATHODE 8 .300 [7.62] .143 [3.63] 8 PDI .072 [1.83] (ACTIVE AREA) 6 7 CL .048 [1.23] (ACTIVE AREA) 2X .053 [1.33] 8 9 CL 10 .100 [2.54] TYP CONFORMAL COAT CL .495 [12.57] .062 [1.57] SURFACE MOUNT PCB PACKAGE ACTIVE AREA = 2.31 mm2 per element +75 O TS Soldering Temperature* +265 O IL Light Current 0.5 C C mA 0.3 0.2 0.1 0 WAVELENGTH (nm) *edge of PCB for 3 secs max ELECTRO-OPTICAL CHARACTERISTICS (TA=25OC unless otherwise noted) SYMBOL CHARACTERISTIC TEST CONDITIONS MIN TYP ISC Short Circuit Current H = 100 fc, 2850 K ID Dark Current H = 0, VR = 5 V Shunt Resistance H = 0, V R = 10 mV TC RSH RSH Temp. Coefficient CJ Junction Capacitance RSH λrange λp V BR NEP tr 1200 -20 1100 Operating Temperature Range 900 TO C 1000 O 800 +100 0% 700 -40 0 =1 QE 0.4 600 Storage Temperature TSTG 0.5 500 V 400 50 0.6 300 Reverse Voltage SPECTRAL RESPONSE 0.7 190 ABSOLUTE MAXIMUM RATING (TA=25OC unless otherwise noted) SYMBOL PARAMETER MIN MAX UNITS V BR APPLICATIONS Card reader Scanners Instrumentation Character recognition DESCRIPTION The PDB-C208 is a silicon, PIN planar diffused, blue enhanced linear array photodiode. Ideal for high speed photoconductive applications. Packaged in low profile surface mount PCB substrate. RESPONSIVITY (A/W) FEATURES .062 inch centers Low cost Blue enhanced Low dark current 18 MAX UNITS mA 28 5 50 nA 200 MΩ H = 0, V R = 10 mV -8 % / oC H = 0, V R = 0 V** 40 Spectral Application Range Spot Scan Spectral Response - Peak Spot Scan Breakdown Voltage I = 10 m A Noise Equivalent Power VR = 10 V @ Peak Response Time RL = 50 Ω VR = 10 V 100 350 15 60 pF 1100 nm 950 nm 30 V -14 3x10 15 W/ Hz nS Information in this technical data sheet is believed to be correct and reliable. However, no responsibility is assumed for possible inaccuracies or omission. Specifications are subject to change without notice. **f = 1 MHz [FORM NO. 100-PDB-C208 REV E]
PDB-C208 价格&库存
很抱歉,暂时无法提供与“PDB-C208”相匹配的价格&库存,您可以联系我们找货
