PHOTONIC
Silicon Photodiode, Blue Enhanced Solderable Chips
Photoconductive Type PDB-C607 Photovoltaic Type PDB-V607
DETECTORS INC.
PACKAGE DIMENSIONS INCH (mm)
0.397 [10.08]
0.397 [10.08]
0.397 [10.08]
1.250 [31.75]
1.00 [25.4]
0.029 [0.74]
0.097 [2.46]
0.097 [2.46]
0.097 [2.46]
ANODE, BUSS WIRE
ANODE, RED WIRE
CATHODE, BLACK WIRE
0.016 [0.41]
0.014 [0.36]
30 GAGE P.V.C. WIRE
30 GAGE BUSS WIRE
ACTIVE AREA = 14.5 mm2
PDB-C607-1
PDB-V607-1
PDB-C607-2
PDB-V607-2
PDB-C607-3
PDB-V607-3
-40 +125 -40 +125
Operating Temperature Range -40 +100 -40 +100
O
TS
Soldering Temperature
+224
+224
O
IL
Light Current
500
500
TSTG
TO
Storage Temperature
ELECTRO-OPTICAL CHARACTERISTICS
SYMBOL CHARACTERISTIC
TEST CONDITIONS
Short Circuit Current
H = 100 fc, 2850 K
ID
Dark Current
H = 0, VR = 5 V*
Shunt Resistance
H = 0, VR = 10 mV
TC RSH
RSH Temp. Coefficient
H = 0, VR = 10 mV
CJ
Junction Capacitance
H = 0, VR = 5 V**
λrange
Spectral Application Range Spot Scan
λp
Spectral Response - Peak Spot Scan
V BR
Breakdown Voltage
N EP
tr
C
C
00
0.3
0.2
0.1
mA
WAVELENGTH (nm)
(TA=25OC unless otherwise noted)
ISC
RSH
C
=1
1100
V
O
QE
0.4
900
25
0.5
1000
75
0.6
800
UNITS
MAX
700
Reverse Voltage
MIN
600
V BR
MAX
SPECTRAL RESPONSE
0.7
500
MIN
Optical encoder
Position sensor
Industrial controls
Instrumentation
400
PARAMETER
PDB-C607 PDB-V607
RESPONSIVITY (A/W)
ABSOLUTE MAXIMUM RATING (TA=25OC unless otherwise noted)
SYMBOL
APPLICATIONS
DESCRIPTION: Low cost blue enhanced planar diffused
silicon solderable photodiode. The PDB-V607 cell is designed
for low noise, photovoltaic applications. The PDB-C607 cell is
designed for low capacitance, high speed, photoconductive
operation. They are available bare, PVC or buss wire leads.
300
Blue enhanced
Photovoltaic type
Photoconductive type
High quantum efficiency
BARE CHIP
190
FEATURES
0.016 [0.41]
0.014 [0.36]
1200
0.016 [0.41]
0.014 [0.36]
I = 10 mA
Noise Equivalent Power
VR = 0 V @ Peak
Response Time
RL = 1 KΩ VR = 5 V**
PDB-C607
PDB-V607
MIN TYP MAX MIN TYP MAX
165
185
15
6
165
35
15
10
-8
125
350
100
8 x 10
-13
25
50
MΩ
-8
% / oC
350
5
TYP
nA
30
2400
1100
940
50
mA
185
25
UNITS
pF
1100
nm
940
nm
10
V
9 x 10
-14
TYP
1000
W/
Hz
nS
*VR = 100 mV on Photovoltaic type
**VR = 0 V on Photovoltaic type
Information in this technical data sheet is believed to be correct and reliable. However, no responsibility is assumed for possible inaccuracies or omission. Specifications
are subject to change without notice.
[FORM NO. 100-PDB-C607-V607 REV A]
很抱歉,暂时无法提供与“PDB-V607-3”相匹配的价格&库存,您可以联系我们找货
