PDB-V604-2
PDB-V604-2
    LUNAOPTOELECTRONICS(Luna Optoelectronics)
    芯片,带30线规PVC导线
    PHOTODIODE BLUE 4.34MM SQ PVC
PDB-V604-2 数据手册
PHOTONIC Silicon Photodiode, Blue Enhanced Solderable Chips Photoconductive Type PDB-C604 Photovoltaic Type PDB-V604 DETECTORS INC. PACKAGE DIMENSIONS INCH (mm) 0.197 [5.00] 0.197 [5.00] 0.197 [5.00] 1.00 [25.4] 1.250 [6.35] 0.030 [0.76] 0.047 [1.19] 0.047 [1.19] 0.047 [1.19] ANODE, BUSS W IRE ANODE, RED W IRE 0.016 [0.41] 0.014 [0.36] 0.016 [0.41] 0.014 [0.36] 0.016 [0.41] 0.014 [0.36] C ATHODE, BLACK W IRE 30 GAGE P.V.C. WIRE 34 GAGE BUSS WIRE PDB-C604-2 PDB-V604-2 PDB-C604-3 PDB-V604-3 V -40 +125 -40 +125 O TO Operating Temperature Range -40 +100 -40 +100 O TS Soldering Temperature +224 +224 O IL Light Current 500 500 TSTG Storage Temperature ELECTRO-OPTICAL CHARACTERISTICS SYMBOL CHARACTERISTIC TEST CONDITIONS Short Circuit Current H = 100 fc, 2850 K ID Dark Current H = 0, VR = 5 V* Shunt Resistance H = 0, VR = 10 mV TC RSH RSH Temp. Coefficient H = 0, VR = 10 mV CJ Junction Capacitance H = 0, VR = 5 V** λrange Spectral Application Range Spot Scan λp Spectral Response - Peak Spot Scan V BR Breakdown Voltage NEP tr C C 0.4 =1 00 % 0.3 0.2 0.1 0 mA WAVELENGTH (nm) (TA=25OC unless otherwise noted) ISC RSH C QE 1200 75 0.5 1000 25 0.6 1100 UNITS MAX 800 Reverse Voltage MIN 900 V BR MAX SPECTRAL RESPONSE 0.7 600 MIN Optical encoder Position sensor Industrial controls Instrumentation 190 PARAMETER PDB-C604 PDB-V604 RESPONSIVITY (A/W) ABSOLUTE MAXIMUM RATING (TA=25OC unless otherwise noted) SYMBOL APPLICATIONS DESCRIPTION: Low cost blue enhanced planar diffused silicon solderable photodiode. The PDB-V604 cell is designed for low noise, photovoltaic applications. The PDB-C604 cell is designed for low capacitance, high speed, photoconductive operation. They are available bare, PVC or buss wire leads. 400 Blue enhanced Photovoltaic type Photoconductive type High quantum efficiency 300 FEATURES 700 ACTIVE AREA = 4.34 mm2 PDB-C604-1 PDB-V604-1 500 BARE CHIP I = 10 mA Noise Equivalent Power VR = 0 V @ Peak Response Time RL = 1 KΩ VR = 5 V** PDB-C604 PDB-V604 MIN TYP MAX MIN TYP MAX 50 68 6 12 45 10 30 30 50 MΩ % / oC 350 8 x 10 -14 15 5 TYP nA -8 600 1100 940 25 25 50 -8 350 mA 58 12 20 UNITS pF 1100 nm 940 nm 15 V 6 x 10 -14 500 TYP W/ Hz nS *VR = 100 mV on Photovoltaic type **VR = 0 V on Photovoltaic type Information in this technical data sheet is believed to be correct and reliable. However, no responsibility is assumed for possible inaccuracies or omission. Specifications are subject to change without notice. [FORM NO. 100-PDB-C604-V604 REV B]
PDB-V604-2 价格&库存
很抱歉,暂时无法提供与“PDB-V604-2”相匹配的价格&库存,您可以联系我们找货
