PHOTONIC
Silicon Photodiode, Blue Enhanced Solderable Chips
Photoconductive Type PDB-C608 Photovoltaic Type PDB-V608
DETECTORS INC.
PACKAGE DIMENSIONS INCH (mm)
0.395 [10.03]
0.395 [10.03]
0.395 [10.03]
1.250 [31.75]
1.00 [25.4]
0.031 [0.79]
0.197 [5.00]
0.197 [5.00]
0.197 [5.00]
ANODE, RED WIRE
ANODE, BUSS W IRE
CATHODE, BLACK W IRE
0.016 [0.41]
0.014 [0.36]
30 GAGE P.V.C. WIRE
30 GAGE BUSS WIRE
PDB-C608-2
PDB-V608-2
PDB-C608-3
PDB-V608-3
V
-40 +125 -40 +125
O
Operating Temperature Range -40 +100 -40 +100
O
TS
Soldering Temperature
+224
+224
O
IL
Light Current
500
500
TO
ELECTRO-OPTICAL CHARACTERISTICS
SYMBOL CHARACTERISTIC
TEST CONDITIONS
Short Circuit Current
H = 100 fc, 2850 K
ID
Dark Current
H = 0, VR = 5 V*
Shunt Resistance
H = 0, VR = 10 mV
TC RSH
RSH Temp. Coefficient
H = 0, VR = 10 mV
CJ
Junction Capacitance
H = 0, VR = 5 V**
λrange
Spectral Application Range Spot Scan
λp
Spectral Response - Peak Spot Scan
V BR
Breakdown Voltage
N EP
tr
C
C
0.4
=1
00
0.3
0.2
0.1
mA
WAVELENGTH (nm)
(TA=25OC unless otherwise noted)
ISC
RSH
C
QE
1000
25
0.5
1100
Storage Temperature
75
0.6
800
TSTG
UNITS
MAX
900
Reverse Voltage
MIN
600
V BR
MAX
0.7
400
MIN
RESPONSIVITY (A/W)
PARAMETER
PDB-C608 PDB-V608
Optical encoder
Position sensor
Industrial controls
Instrumentation
SPECTRAL RESPONSE
ABSOLUTE MAXIMUM RATING (TA=25OC unless otherwise noted)
SYMBOL
APPLICATIONS
DESCRIPTION: Low cost blue enhanced planar diffused
silicon solderable photodiode. The PDB-V608 cell is designed
for low noise, photovoltaic applications. The PDB-C608 cell is
designed for low capacitance, high speed, photoconductive
operation. They are available bare, PVC or buss wire leads.
190
Blue enhanced
Photovoltaic type
Photoconductive type
High quantum efficiency
300
FEATURES
700
ACTIVE AREA = 38.4 mm2
PDB-C608-1
PDB-V608-1
500
BARE CHIP
0.016 [0.41]
0.014 [0.36]
1200
0.016 [0.41]
0.014 [0.36]
I = 10 mA
Noise Equivalent Power
VR = 0 V @ Peak
Response Time
RL = 1 KΩ VR = 5 V**
PDB-C608
PDB-V608
MIN TYP MAX MIN TYP MAX
455
475
25
5
455
50
10
8
-8
200
350
50
2.5 x 10
-13
28
80
MΩ
-8
% / oC
350
5
TYP
nA
1100
940
25
mA
475
40
UNITS
pF
1100
nm
940
nm
15
V
1 x 10
-13
TYP
1200
W/
Hz
nS
*VR = 100 mV on Photovoltaic type
**VR = 0 V on Photovoltaic type
Information in this technical data sheet is believed to be correct and reliable. However, no responsibility is assumed for possible inaccuracies or omission. Specifications
are subject to change without notice.
[FORM NO. 100-PDB-C608-V608 REV A]
很抱歉,暂时无法提供与“PDB-V608-3”相匹配的价格&库存,您可以联系我们找货
