PDU-V102
PDU-V102
    LUNAOPTOELECTRONICS(Luna Optoelectronics)
    TO-46-2透镜顶部金属罐
    PHOTODIODE UV 0.87MM SQ TO-46
PDU-V102 数据手册
PHOTONIC DETECTORS INC. Silicon Photodiode, U.V. Enhanced Photovoltaic Type PDU-V102 PACKAGE DIMENSIONS INCH [mm] WINDOW CAP (WELDED) Ø0.184[4.67] 0.150[3.81] 0.040[1.02] Ø0.155[3.94] 0.060[1.52] WIRE BONDS C L 0.500 [12.70] MIN 45° C L Ø0.210[5.33] PHOTODIODE C L 0.100[2.54] CL 72° VIEWING ANGLE 0.042 [1.06] ANODE Ø0.018[0.46] HEADER CATHODE Ø0.018[0.46] 0.053[1.35] SQUARE 0.030[0.76] ACTIVE AREA TO-46 HERMETIC CAN PACKAGE 0.045[1.14] ACTIVE AREA ACTIVE AREA = .87 mm2 DESCRIPTION The PDU-V102 is a silicon, PIN planar diffused, U.V. enhanced photodiode. Ideal for low noise photovoltaic applications. Packaged in a hermetic TO-46 metal can with a flat U.V. transmitting window. -40 +125 O TS Soldering Temperature* +240 O IL Light Current C C mA 0.3 0.2 0.1 0 *1/16 inch from case for 3 secs max WAVELENGTH (nm) ELECTRO-OPTICAL CHARACTERISTICS (TA=25OC unless otherwise noted) SYMBOL CHARACTERISTIC TEST CONDITIONS MIN TYP ISC Short Circuit Current H = 100 fc, 2850 K ID Dark Current H = 0, V R = 10 mV Shunt Resistance H = 0, V R = 10 mV TC RSH RSH Temp. Coefficient CJ Junction Capacitance RSH λrange R VBR NEP tr 1200 Operating Temperature Range 0.4 1100 TO C 900 O 1000 +150 800 -55 0% =10 QE 0.5 700 Storage Temperature 0.6 600 TSTG 500 V 500 75 400 Reverse Voltage 300 VBR SPECTRAL RESPONSE 0.7 190 ABSOLUTE MAXIMUM RATING (TA=25OC unless otherwise noted) SYMBOL PARAMETER MIN MAX UNITS APPLICATIONS Spectrometers Fluorescent analysers U.V. meters Colorimeters RESPONSIVITY (A/W) FEATURES Low noise U.V. enhanced High shunt resistance U.V. windows 7 MAX UNITS mA 8 1 5 pA 10 GΩ H = 0, V R = 10 mV -8 % / oC H = 0, V R = 0 V** 250 pF Spectral Application Range Spot Scan 2 190 1100 Responsivity VR = 0 V, l = 254 nm Breakdown Voltage I = 10 m A Noise Equivalent Power VR = 10 mV @ Peak 3x10 Response Time RL = 1 KΩ VR = 0 V 400 nm .12 .18 A/W 5 10 V -15 W/ Hz nS Information in this technical data sheet is believed to be correct and reliable. However, no responsibility is assumed for possible inaccuracies or omission. Specifications are subject to change without notice. **f = 1 MHz [FORM NO. 100-PDU-V102 REV A]
PDU-V102 价格&库存
很抱歉,暂时无法提供与“PDU-V102”相匹配的价格&库存,您可以联系我们找货
