PDU-C107
PDU-C107
    LUNAOPTOELECTRONICS(Luna Optoelectronics)
    2-DIP模块
    PHOTODIODE UV 17.74MM SQ CERAMIC
PDU-C107 数据手册
PHOTONIC Silicon Photodiode, U.V. Enhanced Photoconductive Type PDU-C107 DETECTORS INC. PACKAGE DIMENSIONS INCH (mm) + - 0.015[0.38] 0.115[2.92] SOLDER WIRE BONDS 0.308[7.82] 0.037[0.93] REF 0.070[1.78] 0.500 [12.70] MIN CL ANODE 0.265[6.73] CERAMIC CATHODE 120° VIEWING ANGLE Ø0.362[9.19] 0.113 [2.88] REF CL 0.020[0.51 DIA SnPb PLATED Cu PIN - 2 PLACES PHOTODIODE OPTICAL EPOXY 0.235[5.97] 0.135[3.43] 0.123[3.12] ACTIVE AREA 0.223[5.66] ACTIVE AREA CERAMIC PACKAGE ACTIVE AREA = 17.74 mm2 DESCRIPTION The PDU-C107 is a silicon, PIN planar diffused, U.V. enhanced photodiode. Ideal for high speed photoconductive applications. Packaged on a two lead ceramic substrate with a clear U.V. transmitting epoxy glob top. +100 O +240 O IL Light Current 500 C C mA 0.3 0.2 0.1 0 *1/16 inch from case for 3 secs max 1200 -40 1100 Operating Temperature Range 0.4 900 TO C 1000 O 0% 800 +100 0 =1 QE 700 -40 0.5 600 Storage Temperature Soldering Temperature* V 500 TSTG TS 30 0.6 400 Reverse Voltage SPECTRAL RESPONSE 0.7 300 V BR APPLICATIONS U.V. exposure meter Water purification Fluorescence U.V. A & B meters 190 ABSOLUTE MAXIMUM RATING (TA=25OC unless otherwise noted) SYMBOL PARAMETER MIN MAX UNITS RESPONSIVITY (A/W) FEATURES U.V. enhanced Photoconductive High speed Ceramic package WAVELENGTH (nm) ELECTRO-OPTICAL CHARACTERISTICS (TA=25 C unless otherwise noted) SYMBOL CHARACTERISTIC TEST CONDITIONS MIN TYP O ISC Short Circuit Current H = 100 fc, 2850 K ID Dark Current H = 0, V R = 5 V Shunt Resistance H = 0, V R = 10 mV TC RSH RSH Temp. Coefficient H = 0, V R = 10 mV CJ Junction Capacitance H = 0, V R = 5 V** RSH λrange R V BR NEP tr Spectral Application Range Spot Scan 190 -8 % / oC 200 pF 250 1100 .12 .18 Breakdown Voltage I = 10 m A 15 25 Response Time RL = 1 KΩ VR = 5 V nA MΩ VR = 0 V, λ = 254 nm VR = 5 V @ Peak 100 200 Responsivity Noise Equivalent Power UNITS mA 235 50 1000 MAX A/W V -14 3.8x10 65 nm W/ Hz nS Information in this technical data sheet is believed to be correct and reliable. However, no responsibility is assumed for possible inaccuracies or omission. Specifications are subject to change without notice. **f = 1 MHz [FORM NO. 100-PDU-C107 REV A]
PDU-C107 价格&库存
很抱歉,暂时无法提供与“PDU-C107”相匹配的价格&库存,您可以联系我们找货
