PDU-C120
PDU-C120
    LUNAOPTOELECTRONICS(Luna Optoelectronics)
    TO-46-2,金属罐
    PHOTODIODE UV 0.073MM SQ TO-46
PDU-C120 数据手册
PHOTONIC High Speed Silicon Photodiode, U.V. Enhanced Photoconductive Type PDU-C120 DETECTORS INC. PACKAGE DIMENSIONS INCH [mm] CL 0.145 [3.68] 0.040 [1.02] 0.50 [12.7] MIN CL 0.145 [3.68] Ø0.019 [0.48] Ø0.016 [0.41] WIRE BOND Ø0.195 [4.95] Ø0.178 [4.52] CL 0.100 [2.54] ANODE CL Ø0.212 [5.38] Ø0.209 [5.31] 0.027 [0.69] SQUARE Ø0.012 [Ø0.30] ACTIVE AREA CATHODE & CASE PHOTODIODE CHIP WINDOW CAP (WELDED) HEADER 0.025 [0.64] 0.022 [0.56] TO-46 HERMETIC CAN PACKAGE ACTIVE AREA = 0.073 mm2 FEATURES High speed Low cost Hermetically sealed Passivated -55 +125 O TS Soldering Temperature* +240 O IL Light Current 500 C C mA 0.3 0.2 0.1 0 *1/16 inch from case for 3 secs max WAVELENGTH (nm) ELECTRO-OPTICAL CHARACTERISTICS (TA=25OC unless otherwise noted) SYMBOL CHARACTERISTIC TEST CONDITIONS MIN TYP ISC Short Circuit Current H = 100 fc, 2850 K ID Dark Current H = 0, V R = 5 V Shunt Resistance H = 0, V R = 10 mV TC RSH RSH Temp. Coefficient CJ RSH λrange R VBR NEP tr 1200 Operating Temperature Range 1100 TO C 900 O 1000 +150 800 -65 700 Storage Temperature 0.4 600 TSTG % 00 =1 QE 0.5 500 V 400 30 0.6 300 Reverse Voltage SPECTRAL RESPONSE 0.7 190 VBR APPLICATIONS Medical laser Light demodulation Laser detection U.V. receiver RESPONSIVITY (A/W) DESCRIPTION The PDU-C120 is a high speed silicon, PIN planar diffused, U.V. enhanced photodiode. Ideal for high speed U.V., laser detection, switching, and logic applications. Packaged in a hermetic TO-46 metal can with a flat U.V. transmitting window. ABSOLUTE MAXIMUM RATING (TA=25OC unless otherwise noted) SYMBOL PARAMETER MIN MAX UNITS 1.2 MAX UNITS mA 1.5 0.5 2.0 nA 250 MΩ H = 0, V R = 10 mV -8 % / oC Junction Capacitance H = 0, V R = 5 V** 20 pF Spectral Application Range Spot Scan 190 Responsivity VR= 0 V, l= 254 nm .15 .18 Breakdown Voltage I = 10 m A 15 25 Noise Equivalent Power VR = 10 mV @ Peak Response Time RL = 1 KΩ VR = 5 V 200 1100 A/W V -15 9.0x10 5 nm W/ Hz nS Information in this technical data sheet is believed to be correct and reliable. However, no responsibility is assumed for possible inaccuracies or omission. Specifications are subject to change without notice. ** f = 1 MHz [FORM NO. 100-PDU-C120 REV C]
PDU-C120 价格&库存
很抱歉,暂时无法提供与“PDU-C120”相匹配的价格&库存,您可以联系我们找货
