PDU-C113
PDU-C113
    LUNAOPTOELECTRONICS(Luna Optoelectronics)
    2-DIP模块
    PHOTODIODE UV 7.95MM SQ CERAMIC
PDU-C113 数据手册
PHOTONIC Silicon Photodiode, U.V. Enhanced Photoconductive Type PDU-C113 DETECTORS INC. PACKAGE DIMENSIONS INCH (mm) RED DOT INDICATES ANODE 0.140 [3.56] MAX 0.070 [1.78] 0.224 [5.69] 1.50 [38.1] MIN WIRE BONDS ANODE PHOTODIODE CL 120° VIEWING ANGLE Ø0.265 [6.73] 0.200 [5.08] CL Ø0.020 [0.51] OPTICAL EPOXY CATHODE CERAMIC 0.125 [3.18] SQUARE CERAMIC PACKAGE 0.113 [2.87] SQ ACTIVE AREA ACTIVE AREA = 7.95 mm2 O +240 O IL Light Current 500 C C mA 0.3 0.2 0.1 0 WAVELENGTH (nm) *1/16 inch from case for 3 secs max ELECTRO-OPTICAL CHARACTERISTICS (TA=25OC unless otherwise noted) SYMBOL CHARACTERISTIC TEST CONDITIONS MIN TYP ISC Short Circuit Current H = 100 fc, 2850 K ID Dark Current H = 0, VR = 5 V Shunt Resistance H = 0, V R = 10 mV TC RSH RSH Temp. Coefficient H = 0, V R = 10 mV CJ Junction Capacitance H = 0, V R = 5 V** RSH λrange R V BR NEP tr Spectral Application Range Spot Scan 90 -8 % / oC 130 pF 250 1100 .12 .18 Breakdown Voltage I = 10 m A 15 25 Response Time RL = 1 KΩ VR = 5 V nA MΩ VR = 0 V, λ = 254 nm VR = 5 V @ Peak 50 250 Responsivity Noise Equivalent Power UNITS mA 110 10 100 MAX 2.2x10 58 1200 +90 1100 -40 0.4 900 Operating Temperature Range C 1000 O 800 +100 0% 700 -40 0 =1 QE 0.5 600 Storage Temperature Soldering Temperature* V 500 TSTG TS 30 400 Reverse Voltage 0.6 300 V BR SPECTRAL RESPONSE 0.7 190 ABSOLUTE MAXIMUM RATING (TA=25OC unless otherwise noted) SYMBOL PARAMETER MIN MAX UNITS TO APPLICATIONS U.V. exposure meter Water purification Fluorescence U.V. A & B meters DESCRIPTION The PDU-C113 is a silicon, PIN planar diffused, U.V. enhanced photodiode. Ideal for high speed photoconductive applications. Packaged on a two lead ceramic substrate with a clear U.V. transmitting epoxy glob top. RESPONSIVITY (A/W) FEATURES High speed Low capacitance U.V. enhanced Low dark current nm A/W V -14 W/ Hz nS Information in this technical data sheet is believed to be correct and reliable. However, no responsibility is assumed for possible inaccuracies or omission. Specifications are subject to change without notice. ** f = 1 MHz [FORM NO. 100-PDU-C113 REV A]
PDU-C113 价格&库存
很抱歉,暂时无法提供与“PDU-C113”相匹配的价格&库存,您可以联系我们找货
