PDU-C119
PDU-C119
    LUNAOPTOELECTRONICS(Luna Optoelectronics)
    TO-5
    PHOTODIODE UV 7.95MM SQ TO-5
PDU-C119 数据手册
PHOTONIC Silicon Photodiode, U.V. Enhanced Photoconductive (SFH 291 Industry Equivalent) Type PDU-C119 DETECTORS INC. PACKAGE DIMENSIONS INCH [mm] WINDOW CAP (WELDED) Ø0.325 [8.25] Ø0.250 [6.35] 0.168 [4.26] 0.030 [0.76] CL 0.075 [1.91] WIRE BONDS 0.500 [12.70] MIN 45° CL Ø0.358 [9.09] 68° VIEWING ANGLE CL 0.200 [5.08] 0.035 [0.89] C L ANODE Ø0.018 [0.46] HEADER CATHODE Ø0.018 [0.46] PHOTODIODE 0.125 [3.175] SQ 0.113 [2.87] SQ ACTIVE AREA TO-5 HERMETIC CAN PACKAGE ACTIVE AREA = 7.95 mm2 APPLICATIONS DESCRIPTION The PDU-C119 is a silicon, PIN planar Spectrometers diffused, U.V. enhanced photodiode. Ideal Fluorescent analysers for high speed photoconductive U.V. applica- U.V. meters tions.Packaged in a hermetic TO-5 metal Colorimeters can with a U.V transmitting window cap. Light Current O 500 C mA 0.2 0.1 0 WAVELENGTH (nm) *1/16 inch from case for 3 secs max ELECTRO-OPTICAL CHARACTERISTICS (TA=25OC unless otherwise noted) SYMBOL CHARACTERISTIC TEST CONDITIONS MIN TYP E c = 0.1 mW/cm 2, l=350 nm ISC Short Circuit Current ID Dark Current H = 0, V R = 5 V Shunt Resistance H = 0, V R = 10 mV TC RSH RSH Temp. Coefficient CJ Junction Capacitance RSH λrange R V BR NEP tr 1200 IL +240 C 0.3 1100 Soldering Temperature* +125 0.4 900 TS -40 O C 1000 Operating Temperature Range O 0% 800 TO +150 0 =1 QE 700 -55 0.5 600 Storage Temperature V 500 TSTG 30 400 Reverse Voltage 0.6 300 V BR SPECTRAL RESPONSE 0.7 190 ABSOLUTE MAXIMUM RATING (TA=25OC unless otherwise noted) SYMBOL PARAMETER MIN MAX UNITS RESPONSIVITY (A/W) FEATURES High speed U.V. enhanced U.V window .6 MAX UNITS mA 1.0 2.5 5 nA 300 MΩ H = 0, V R = 10 mV -8 % / oC H = 0, V R = 0 V** 130 pF Spectral Application Range Spot Scan 150 190 1100 Responsivity VR = 0 V, l = 254 nm .12 .18 Breakdown Voltage I = 10 m A 15 25 Noise Equivalent Power VR = 10 mV @ Peak Response Time RL = 1 KΩ VR = 5 V 2.2x10 58 nm A/W V -14 W/ Hz nS Information in this technical data sheet is believed to be correct and reliable. However, no responsibility is assumed for possible inaccuracies or omission. Specifications are subject to change without notice. **f = 1 MHz [FORM NO. 100-PDU-C119 REV B]
PDU-C119 价格&库存
很抱歉,暂时无法提供与“PDU-C119”相匹配的价格&库存,您可以联系我们找货
