PDU-V107
PDU-V107
    LUNAOPTOELECTRONICS(Luna Optoelectronics)
    2-DIP模块
    PHOTODIODE UV 17.74MM SQ CERAMIC
PDU-V107 数据手册
PHOTONIC Silicon Photodiode, U.V. DETECTORS INC. Enhanced Photovoltaic Type PDU-V107 PACKAGE DIMENSIONS INCH (mm) + - 0.015[0.38] 0.115[2.92] SOLDER WIRE BONDS 0.308[7.82] 0.037[0.93] REF 0.070[1.78] 0.500 [12.70] MIN CL ANODE 0.265[6.73] CERAMIC CATHODE 120° VIEWING ANGLE Ø0.362[9.19] 0.113 [2.88] REF CL 0.020[0.51 DIA SnPb PLATED Cu PIN - 2 PLACES PHOTODIODE OPTICAL EPOXY 0.235[5.97] 0.135[3.43] 0.123[3.12] ACTIVE AREA 0.223[5.66] ACTIVE AREA CERAMIC PACKAGE ACTIVE AREA = 17.74 mm2 DESCRIPTION The PDU-V107 is a silicon, PIN planar diffused, U.V. enhanced photodiode. Ideal for low noise photovoltaic applications. Packaged on a two lead ceramic substrate with a clear U.V. epoxy glob top. -40 +90 O TS Soldering Temperature* +240 O IL Light Current C C mA 0.3 0.2 0.1 0 *1/16 inch from case for 3 secs max 1200 Operating Temperature Range 0.4 1100 TO C 900 O 1000 +100 800 -40 % 00 =1 E Q 0.5 700 Storage Temperature 0.6 600 TSTG 500 V 500 75 400 Reverse Voltage 300 V BR SPECTRAL RESPONSE 0.7 190 ABSOLUTE MAXIMUM RATING (TA=25OC unless otherwise noted) SYMBOL PARAMETER MIN MAX UNITS APPLICATIONS U.V. exposure meter Water purification Fluorescence U.V. A & B meters RESPONSIVITY (A/W) FEATURES Low noise U.V. enhanced High shunt resistance High response WAVELENGTH (nm) ELECTRO-OPTICAL CHARACTERISTICS (TA=25 C unless otherwise noted) SYMBOL CHARACTERISTIC TEST CONDITIONS MIN TYP O ISC Short Circuit Current H = 100 fc, 2850 K ID Dark Current H = 0, V R = 10 V Shunt Resistance H = 0, V R = 10 mV TC RSH RSH Temp. Coefficient H = 0, V R = 10 mV CJ Junction Capacitance H = 0, V R = 0 V** RSH λrange λp Spectral Application Range Spot Scan 180 800 MΩ -8 % / oC 2000 pF 1100 Spectral Response - Peak Spot Scan V BR Breakdown Voltage I = 10 m A NEP Noise Equivalent Power VR = 10 mV @ Peak 2.0x10 Response Time RL = 1 KΩ VR = 0 V 1000 tr pA 500 250 850 30 UNITS mA 200 400 100 MAX nm nm 50 V -13 W/ Hz nS Information in this technical data sheet is believed to be correct and reliable. However, no responsibility is assumed for possible inaccuracies or omission. Specifications are subject to change without notice.**f = 1 MHz [FORM NO. 100-PDU-V107 REV A]
PDU-V107 价格&库存
很抱歉,暂时无法提供与“PDU-V107”相匹配的价格&库存,您可以联系我们找货
