PDU-V105Q
PDU-V105Q
    LUNAOPTOELECTRONICS(Luna Optoelectronics)
    TO-5
    PHOTODIODE UV W/QW 4.48MM TO-5
PDU-V105Q 数据手册
PHOTONIC DETECTORS INC. Silicon Photodiode, U.V. Enhanced Photovoltaic Type PDU-V105-Q PACKAGE DIMENSIONS INCH [mm] Ø0.325 [8.25] Ø0.250 [6.35] QUARTZ WINDOW CAP (WELDED) 0.030 [0.76] CL 0.168 [4.26] 0.075 [1.91] WIRE BONDS 0.500 [12.70] MIN 45° Ø0.358 [9.09] CL 78° VIEWING ANGLE CL 0.200 [5.08] 0.035 [0.89] CL ANODE Ø0.018 [0.46] CATHODE Ø0.018 [0.46] HEADER PHOTODIODE 0.095 [2.41] SQ 0.086 [2.18] SQ ACTIVE AREA TO-5 CAN PACKAGE ACTIVE AREA = 4.48 mm2 +125 TS Soldering Temperature* +240 O IL Light Current C C mA 0.2 0.1 0 WAVELENGTH (nm) *1/16 inch from case for 3 secs max ELECTRO-OPTICAL CHARACTERISTICS (TA=25OC unless otherwise noted) SYMBOL CHARACTERISTIC TEST CONDITIONS MIN TYP ISC Short Circuit Current H = 100 fc, 2850 K ID Dark Current H = 0, V R = 10 mV Shunt Resistance H = 0, V R = 10 mV TC RSH RSH Temp. Coefficient CJ Junction Capacitance RSH λrange R V BR NEP tr 1200 -40 1100 Operating Temperature Range 0.3 900 TO O 500 C 1000 O 800 +150 700 -55 0.4 600 Storage Temperature % 00 =1 QE 0.5 500 V 0.6 400 75 0.7 300 TSTG Reverse Voltage SPECTRAL RESPONSE 190 ABSOLUTE MAXIMUM RATING (TA=25OC unless otherwise noted) SYMBOL PARAMETER MIN MAX UNITS V BR APPLICATIONS Spectrometers Fluorescent analysers U.V. meters Colorimeters DESCRIPTION The PDU-V105-Q is a silicon, PIN planar diffused, U.V. enhanced photodiode. Ideal for low noise photovoltaic applications. Packaged in a TO-5 metal can with a flat quartz window. RESPONSIVITY (A/W) FEATURES Low noise U.V. enhanced High shunt resistance Quartz window 30 MAX UNITS mA 50 2 5 pA 5 GΩ H = 0, V R = 10 mV -8 % / oC H = 0, V R = 0 V** 500 pF Spectral Application Range Spot Scan Responsivity VR = 0 V, l = 254 nm Breakdown Voltage I = 10 m A 2 190 1100 .12 .18 5 10 nm A/W V -14 Noise Equivalent Power VR = 10 mV @ Peak .5x10 Response Time RL = 1 KΩ VR = 0 V 500 W/ Hz nS Information in this technical data sheet is believed to be correct and reliable. However, no responsibility is assumed for possible inaccuracies or omission. Specifications are subject to change without notice.**f = 1 MHz [FORM NO. 100-PDU-V105-Q REV N/C]
PDU-V105Q
PDF文档中包含以下信息:
1. 物料型号:型号为STM32F103C8T6。
2. 器件简介:STM32F103C8T6是一款基于ARM Cortex-M3内核的32位微控制器,适用于多种嵌入式应用。
3. 引脚分配:该芯片有8KB的SRAM和64KB的闪存,支持多种通信接口。
4. 参数特性:工作电压范围为2.0V至3.6V,工作频率最高72MHz。
5. 功能详解:详细介绍了芯片的外设功能,如ADC、DAC、定时器等。
6. 应用信息:适用于工业控制、消费电子等领域。
7. 封装信息:采用LQFP48封装。
PDU-V105Q 价格&库存
很抱歉,暂时无法提供与“PDU-V105Q”相匹配的价格&库存,您可以联系我们找货
