PDU-V105
PDU-V105
    LUNAOPTOELECTRONICS(Luna Optoelectronics)
    TO-5
    PHOTODIODE UV 4.48MM SQ TO-5
PDU-V105 数据手册
PHOTONIC DETECTORS INC. Silicon Photodiode, U.V. Enhanced Photovoltaic Type PDU-V105 PACKAGE DIMENSIONS INCH [mm] WINDOW CAP (WELDED) 0.030 [0.76] Ø0.325 [8.25] Ø0.250 [6.35] C L 0.168 [4.26] 0.075 [1.91] WIRE BONDS 0.500 [12.70] MIN 45° Ø0.358 [9.09] 78° VIEWING ANGLE CL C L 0.200 [5.08] 0.035 [0.89] C L ANODE Ø0.018 [0.46] CATHODE Ø0.018 [0.46] HEADER PHOTODIODE 0.095 [2.41] SQ TO-5 HERMETIC CAN PACKAGE 0.086 [2.18] SQ ACTIVE AREA ACTIVE AREA = 4.48 mm2 +125 TS Soldering Temperature* +240 O IL Light Current C C mA 0.2 0.1 0 WAVELENGTH (nm) *1/16 inch from case for 3 secs max ELECTRO-OPTICAL CHARACTERISTICS (TA=25OC unless otherwise noted) SYMBOL CHARACTERISTIC TEST CONDITIONS MIN TYP ISC Short Circuit Current H = 100 fc, 2850 K ID Dark Current H = 0, V R = 10 mV Shunt Resistance H = 0, V R = 10 mV TC RSH RSH Temp. Coefficient CJ Junction Capacitance RSH λrange R V BR NEP tr 1200 -40 1100 Operating Temperature Range 0.3 900 TO O 500 C 1000 O 800 +150 700 -55 0.4 600 Storage Temperature % 00 =1 QE 0.5 500 V 0.6 400 75 0.7 300 TSTG Reverse Voltage SPECTRAL RESPONSE 190 ABSOLUTE MAXIMUM RATING (TA=25OC unless otherwise noted) SYMBOL PARAMETER MIN MAX UNITS V BR APPLICATIONS Spectrometers Fluorescent analysers U.V. meters Colorimeters DESCRIPTION The PDU-V105 is a silicon, PIN planar diffused, U.V. enhanced photodiode. Ideal for low noise photovoltaic applications. Packaged in a hermetic TO-5 metal can with a flat U.V. transmitting window. RESPONSIVITY (A/W) FEATURES Low noise U.V. enhanced High shunt resistance U.V window 30 MAX UNITS mA 50 2 5 pA 5 GΩ H = 0, V R = 10 mV -8 % / oC H = 0, V R = 0 V** 500 pF Spectral Application Range Spot Scan Responsivity VR = 0 V, l = 254 nm Breakdown Voltage I = 10 m A 2 190 1100 .12 .18 5 10 nm A/W V -14 Noise Equivalent Power VR = 10 mV @ Peak .5x10 Response Time RL = 1 KΩ VR = 0 V 500 W/ Hz nS Information in this technical data sheet is believed to be correct and reliable. However, no responsibility is assumed for possible inaccuracies or omission. Specifications are subject to change without notice.**f = 1 MHz [FORM NO. 100-PDU-V105 REV A]
PDU-V105 价格&库存
很抱歉,暂时无法提供与“PDU-V105”相匹配的价格&库存,您可以联系我们找货
