PDU-V109Q
PDU-V109Q
    LUNAOPTOELECTRONICS(Luna Optoelectronics)
    TO8-3
    PHOTODIODE UV W/QW 42.86MM TO-8
PDU-V109Q 数据手册
PHOTONIC DETECTORS INC. Silicon Photodiode, U.V. Enhanced Photovoltaic Type PDU-V109-Q PACKAGE DIMENSIONS INCH [mm] Ø0.483 [12.27] Ø0.449 [11.39] 0.215 [5.46] 0.065 [1.65] WIRE BONDS 1.50 [38.1] CL 79° VIEWING ANGLE Ø0.550 [13.97] 0.295 [7.49] ANODE Ø0.018 [0.46] CL CATHODE Ø0.018 [0.46] HEADER QUARTZ WINDOW CAP (WELDED) PHOTODIODE 0.340 [8.64] 0.230 [5.84] 0.209 [5.31] ACTIVE AREA TO-8 PACKAGE 0.319 [8.10] ACTIVE AREA ACTIVE AREA = 42.86 mm2 DESCRIPTION The PDU-V109-Q is a silicon, PIN planar diffused, U.V. enhanced photodiode. Ideal for low noise photovoltaic applications. Packaged in a TO-8 metal can with a flat quartz window. -40 +125 O TS Soldering Temperature* +240 O IL Light Current C C mA 0.3 0.2 0.1 0 *1/16 inch from case for 3 secs max WAVELENGTH (nm) ELECTRO-OPTICAL CHARACTERISTICS (TA=25OC unless otherwise noted) SYMBOL CHARACTERISTIC TEST CONDITIONS MIN TYP ISC Short Circuit Current H = 100 fc, 2850 K ID Dark Current H = 0, V R = 10 mV Shunt Resistance H = 0, V R = 10 mV TC RSH RSH Temp. Coefficient H = 0, V R = 10 mV CJ Junction Capacitance H = 0, V R = 0 V** RSH λrange Spectral Application Range Spot Scan 405 200 pA 150 MΩ -8 % / oC 4,500 pF 190 1100 VR = 0 V, l = 254 nm V BR Breakdown Voltage I = 10 m A NEP Noise Equivalent Power VR = 10 mV @ Peak 1.0x10 Response Time RL = 1 KΩ VR = 0 V 1,000 tr UNITS mA 66 50 MAX 500 Responsivity R 1200 Operating Temperature Range 1100 TO 500 C 900 O 1000 +150 800 -55 0.4 700 Storage Temperature % 00 =1 E Q 0.5 600 V 500 75 400 TSTG Reverse Voltage 0.6 300 V BR SPECTRAL RESPONSE 0.7 190 ABSOLUTE MAXIMUM RATING (TA=25OC unless otherwise noted) SYMBOL PARAMETER MIN MAX UNITS APPLICATIONS Spectrometers Fluorescent analysers U.V. meters Colorimeters RESPONSIVITY (A/W) FEATURES Low noise U.V. enhanced High shunt resistance Quartz window .12 .18 5 10 nm A/W V -14 W/ Hz nS Information in this technical data sheet is believed to be correct and reliable. However, no responsibility is assumed for possible inaccuracies or omission. Specifications are subject to change without notice.**f = 1 MHz [FORM NO. 100-PDU-V109-Q REV N/C]
PDU-V109Q 价格&库存
很抱歉,暂时无法提供与“PDU-V109Q”相匹配的价格&库存,您可以联系我们找货
