PDU-V108Q
PDU-V108Q
    LUNAOPTOELECTRONICS(Luna Optoelectronics)
    TO8-3
    Photodiode 950ns 69° TO-233AA, TO-8-3 Lens Top Metal Can
PDU-V108Q 数据手册
PHOTONIC DETECTORS INC. Silicon Photodiode, U.V. Enhanced Photovoltaic Type PDU-V108-Q PACKAGE DIMENSIONS INCH [mm] 0.215 [5.46] Ø0.483 [12.27] 0.065 [1.65] Ø0.449 [11.39] 1.500 [38.10] WIRE BONDS CL 69° VIEWING ANGLE Ø0.550 [13.97] ANODE Ø0.018 [0.46] 0.295 [7.49] CL CATHODE Ø0.018 [0.46] HEADER PHOTODIODE QUARTZ WINDOW CAP (WELDED) 0.265 [6.74] SQUARE 0.2472 [6.289] ACTIVE AREA TO-8 PACKAGE ACTIVE AREA = 31.00 mm2 DESCRIPTION The PDU-V108-Q is a silicon, PIN planar diffused, U.V. enhanced photodiode. Ideal for low noise photovoltaic applications. Packaged in a TO-8 metal can with a flat quartz window. -40 +125 O TS Soldering Temperature* +240 O IL Light Current C C mA 0.3 0.2 0.1 0 *1/16 inch from case for 3 secs max WAVELENGTH (nm) ELECTRO-OPTICAL CHARACTERISTICS (TA=25OC unless otherwise noted) SYMBOL CHARACTERISTIC TEST CONDITIONS MIN TYP ISC Short Circuit Current H = 100 fc, 2850 K ID Dark Current H = 0, V R = 10 mV Shunt Resistance H = 0, V R = 10 mV TC RSH RSH Temp. Coefficient H = 0, V R = 10 mV CJ Junction Capacitance H = 0, V R = 0 V** RSH λrange Spectral Application Range Spot Scan 375 10 .2 UNITS mA 50 pA 1 GΩ -8 % / oC 2500 pF 190 1100 VR = 0 V, l = 254 nm V BR Breakdown Voltage I = 10 m A NEP Noise Equivalent Power VR = 10 mV @ Peak 5x10 Response Time RL = 1 KΩ VR = 0 V 950 tr MAX 430 Responsivity R 1200 Operating Temperature Range 1100 TO 500 C 900 O 1000 +150 800 -55 0.4 700 Storage Temperature % 00 =1 E Q 0.5 600 V 500 75 400 TSTG Reverse Voltage 0.6 300 V BR SPECTRAL RESPONSE 0.7 190 ABSOLUTE MAXIMUM RATING (TA=25OC unless otherwise noted) SYMBOL PARAMETER MIN MAX UNITS APPLICATIONS Spectrometers Fluorescent analysers U.V. meters Colorimeters RESPONSIVITY (A/W) FEATURES Low noise U.V. enhanced High shunt resistance Quartz window nm .12 .18 A/W 5 10 V -14 W/ Hz nS Information in this technical data sheet is believed to be correct and reliable. However, no responsibility is assumed for possible inaccuracies or omission. Specifications are subject to change without notice.**f = 1 MHz [FORM NO. 100-PDU-V108-Q REV N/C]
PDU-V108Q 价格&库存
很抱歉,暂时无法提供与“PDU-V108Q”相匹配的价格&库存,您可以联系我们找货
