PDU-V110
PDU-V110
    LUNAOPTOELECTRONICS(Luna Optoelectronics)
    2-DIP模块
    PHOTODIODE UV 100MM SQ CERAMIC
PDU-V110 数据手册
PHOTONIC DETECTORS INC. Silicon Photodiode, U.V. Enhanced Photovoltaic Type PDU-V110 PACKAGE DIMINSIONS INCH (mm) 0.592 [15.04] 0.409 [10.39] SQUARE 0.080 [2.03] NOTCH INDICATES ANODE PIN WIRE BONDS 0.50 [12.7] QUARTZ WINDOW CL WHITE CERAMIC 0.650 [16.51] ANODE 120° VIEWING ANGLE 0.484 [12.29] PHOTODIODE CHIP CL Ø0.017 [0.43] 2 PLACES CERAMIC PACKAGE ACTIVE AREA = 100.00 mm2 0.5 C mA 0 .2 0 .1 0 *1/16 inch from case for 3 secs max WAVELENGTH (nm) ELECTRO-OPTICAL CHARACTERISTICS (TA=25OC unless otherwise noted) SYMBOL CHARACTERISTIC TEST CONDITIONS MIN TYP ISC Short Circuit Current ID Dark Current H = 0, VR = 10 mV Shunt Resistance H = 0, VR = 10 mV TC RSH RSH Temp. Coefficient CJ Junction Capacitance RSH λrange H = 100 fc, 2850 K 0.9 200 UNITS mA 333 pA 50 MΩ H = 0, VR = 10 mV -8 % / oC H = 0, VR = 0 V** 10,000 30 Spot Scan 190 Responsivity VR = 0 V, l= 254 nm .12 V BR Breakdown Voltage I = 10 mA N EP Noise Equivalent Power VR = 10 mV @ Peak 2.0x10-14 Response Time RL = 1 KΩ VR = 0 V 2000 tr MAX 1.2 Spectral Application Range R 1200 Light Current O 0 .3 1000 IL +220 C % 1100 Soldering Temperature* +60 C 00 800 TS -20 O =1 900 Operating Temperature Range O QE 0 .4 600 TO +80 0 .5 700 -20 0 .6 400 Storage Temperature V 500 75 190 TSTG Reverse Voltage SPECTRAL RESPONSE 0 .7 300 ABSOLUTE MAXIMUM RATING (TA=25OC unless otherwise noted) SYMBOL PARAMETER MIN MAX UNITS V BR APPLICATIONS Spectometers Fluorescent analysers U.V. meters Colorimeters DESCRIPTION The PDU-V110 is a silicon, PIN planar diffused, U.V. enhanced photodiode. Ideal for low noise photovoltaic applications. Packaged in low profile ceramic substrate with a quartz window. RESPONSIVITY (A/W) FEATURES Low noise U.V. enhanced High shunt resistance Quartz windows CATHODE 5 12,000 1100 .18 pF nm A/W 10 V W/ Hz nS Information in this technical data sheet is believed to be correct and reliable. However, no responsibility is assumed for possible inaccuracies or omission. Specifications are subject to change without notice.**f = 1 MHz [FORM NO. 100-PDU-V110 REV N/C]
PDU-V110 价格&库存
很抱歉,暂时无法提供与“PDU-V110”相匹配的价格&库存,您可以联系我们找货
