PDU-V110Q
PDU-V110Q
    LUNAOPTOELECTRONICS(Luna Optoelectronics)
    2-DIP模块
    PHOTODIODE UV W/QW 100MM CERAMIC
PDU-V110Q 数据手册
PHOTONIC DETECTORS INC. Silicon Photodiode, U.V. Enhanced Photovoltaic Type PDU-V110-Q PACKAGE DIMENSIONS INCH (mm) 0.592 [15.04] 0.409 [10.39] SQUARE WIRE BONDS 0.080 [2.03] NOTCH INDICATES ANODE PIN 0.50 [12.7] QUARTZ WINDOW CL 0.484 [12.29] PHOTODIODE CHIP C L Ø0.017 [0.43] 2 PLACES CERAMIC PACKAGE ACTIVE AREA = 100.00 mm2 Operating Temperature Range -20 +60 O TS Soldering Temperature* +220 O IL Light Current C C mA 0.3 0.2 0.1 0 WAVELENGTH (nm) *1/16 inch from case for 3 secs max ELECTRO-OPTICAL CHARACTERISTICS (TA=25OC unless otherwise noted) SYMBOL CHARACTERISTIC TEST CONDITIONS MIN TYP ISC Short Circuit Current H = 100 fc, 2850 K ID Dark Current H = 0, V R = 10 mV Shunt Resistance H = 0, V R = 10 mV TC RSH RSH Temp. Coefficient H = 0, V R = 10 mV CJ Junction Capacitance H = 0, V R = 0 V** RSH λrange R V BR NEP tr 1200 TO 500 C 900 O 800 +80 0.4 700 -20 % 00 =1 QE 0.5 600 Storage Temperature 0.6 500 V 400 75 300 TSTG Reverse Voltage SPECTRAL RESPONSE 0.7 190 ABSOLUTE MAXIMUM RATING (TA=25OC unless otherwise noted) SYMBOL PARAMETER MIN MAX UNITS V BR APPLICATIONS Spectometers Fluorescent analysers U.V. meters Colorimeters DESCRIPTION The PDU-V110-Q is a silicon, PIN planar diffused, U.V. enhanced photodiode. Ideal for low noise photovoltaic applications. Packaged in low profile ceramic substrate with a quartz window. RESPONSIVITY (A/W) FEATURES Low noise U.V. enhanced High shunt resistance Quartz window CATHODE 1100 0.650 [16.51] ANODE 120° VIEWING ANGLE 1000 WHITE CERAMIC Spectral Application Range Spot Scan Responsivity VR = 0 V, l= 254 nm Breakdown Voltage I = 10 m A 0.9 333 MΩ -8 % / oC 190 5 pA 50 10,000 .12 UNITS mA 1.2 200 30 MAX .18 10 Noise Equivalent Power VR = 10 mV @ Peak 2.0x10 Response Time RL = 1 KΩ VR = 0 V 2000 12,000 pF 1100 nm A/W V -14 W/ Hz nS Information in this technical data sheet is believed to be correct and reliable. However, no responsibility is assumed for possible inaccuracies or omission. Specifications are subject to change without notice.**f = 1 MHz [FORM NO. 100-PDU-V110-Q REV N/C]
PDU-V110Q 价格&库存
很抱歉,暂时无法提供与“PDU-V110Q”相匹配的价格&库存,您可以联系我们找货
