PDU-V111Q
PDU-V111Q
    LUNAOPTOELECTRONICS(Luna Optoelectronics)
    TO8-3
    PHOTODIODE UV W/QW 100.2MM TO-8
PDU-V111Q 数据手册
PHOTONIC DETECTORS INC. Silicon Photodiode, U.V. Enhanced Photovoltaic Type PDU-V111-Q PACKAGE DIMENSIONS INCH (mm) Ø0.795 Ø[20.19] Ø0.500 [Ø12.70] PIN CIRCLE 0.230 [5.84] Ø0.720 Ø[18.29] 0.165 [4.19] QUARTZ WINDOW CAP Ø0.608 Ø[15.44] ANODE 0.375 [9.53] Ø0.030 [0.76] TYP WIRE BONDS VIEWING ANGLE 54° Ø0.4447 ACTIVE AREA HEADER 0.030[0.76] PHOTODIODE CHIP UNUSED PIN 0.200 [5.08] CATHODE CASE GROUND TO-8 .795 INCH (20.19) DIA PACKAGE ACTIVE AREA = 100.20 mm2 +125 O TS Soldering Temperature* +224 O IL Light Current C C mA 0.3 0.2 0.1 0 *1/16 inch from case for 3 secs max WAVELENGTH (nm) ELECTRO-OPTICAL CHARACTERISTICS (TA=25OC unless otherwise noted) SYMBOL CHARACTERISTIC TEST CONDITIONS MIN TYP ISC Short Circuit Current H = 100 fc, 2850 K ID Dark Current H = 0, V R = 10 mV Shunt Resistance H = 0, V R = 10 mV TC RSH RSH Temp. Coefficient H = 0, V R = 10 mV CJ Junction Capacitance H = 0, V R = 0 V** RSH λrange R V BR NEP tr 1200 -40 1100 Operating Temperature Range 900 TO 500 C 1000 O 800 +150 700 -55 % 00 =1 E Q 0.4 600 Storage Temperature 0.5 500 V 400 75 0.6 300 TSTG Reverse Voltage SPECTRAL RESPONSE 0.7 190 ABSOLUTE MAXIMUM RATING (TA=25OC unless otherwise noted) SYMBOL PARAMETER MIN MAX UNITS V BR APPLICATIONS Spectrometers Fluorescent analysers U.V. meters Colorimeters DESCRIPTION The PDU-V111-Q is a silicon, PIN planar diffused, U.V. enhanced photodiode. Ideal for low noise photovoltaic applications. Packaged in a low cost TO-8 metal can with a flat quartz window. RESPONSIVITY (A/W) FEATURES Low noise U.V. enhanced High shunt resistance Quartz window Spectral Application Range Spot Scan Responsivity VR = 0 V, l = 254 nm Breakdown Voltage I = 10 m A Noise Equivalent Power VR = 10 mV @ Peak Response Time RL = 1 KΩ VR = 0 V 0.9 1.2 200 30 MAX UNITS mA 333 pA 50 MΩ -8 % / oC 10,000 190 12,000 pF 1100 nm .12 .18 A/W 5 10 V -14 2x10 2000 W/ Hz nS Information in this technical data sheet is believed to be correct and reliable. However, no responsibility is assumed for possible inaccuracies or omission. Specifications are subject to change without notice. **f = 1 MHz [FORM NO. 100-PDU-V111-Q REV B]
PDU-V111Q 价格&库存
很抱歉,暂时无法提供与“PDU-V111Q”相匹配的价格&库存,您可以联系我们找货
