PDU-V109
PDU-V109
    LUNAOPTOELECTRONICS(Luna Optoelectronics)
    TO8-3
    PHOTODIODE UV 42.86MM SQ TO-8
PDU-V109 数据手册
PHOTONIC DETECTORS INC. Silicon Photodiode, U.V. Enhanced Photovoltaic Type PDU-V109 PACKAGE DIMENSIONS INCH [mm] Ø0.483 [12.27] Ø0.449 [11.39] 0.215 [5.46] 0.065 [1.65] WIRE BONDS 1.50 [38.1] C L 79° VIEWING ANGLE Ø0.550 [13.97] 0.295 [7.49] ANODE Ø0.018 [0.46] CL CATHODE Ø0.018 [0.46] HEADER WINDOW CAP (WELDED) PHOTODIODE 0.340 [8.64] 0.230 [5.84] 0.209 [5.31] ACTIVE AREA TO-8 HERMETIC PACKAGE 0.319 [8.10] ACTIVE AREA ACTIVE AREA = 42.86 mm2 DESCRIPTION The PDU-V109 is a silicon, PIN planar diffused, U.V. enhanced photodiode. Ideal for low noise photovoltaic applications. Packaged in a hermetic TO-8 metal can with a flat quartz window. Light Current O 0.5 C mA 0 .3 0 .2 0 .1 0 *1/16 inch from case for 3 secs max WAVELENGTH (nm) ELECTRO-OPTICAL CHARACTERISTICS (TA=25OC unless otherwise noted) SYMBOL CHARACTERISTIC TEST CONDITIONS MIN TYP ISC Short Circuit Current ID Dark Current H = 0, VR = 10 mV Shunt Resistance H = 0, VR = 10 mV TC RSH RSH Temp. Coefficient CJ Junction Capacitance RSH λrange H = 100 fc, 2850 K UNITS mA 500 50 150 MΩ H = 0, VR = 10 mV -8 % / oC H = 0, VR = 0 V** 4,500 pF 66 Spot Scan 190 Responsivity VR = 0 V, l = 254 nm .12 V BR Breakdown Voltage I = 10 mA N EP Noise Equivalent Power VR = 10 mV @ Peak 1.0x10-14 Response Time RL = 1 KΩ VR = 0 V 1,000 tr MAX 405 Spectral Application Range R 1200 IL +240 C % 1000 Soldering Temperature* +125 C 00 1100 TS -40 O =1 800 Operating Temperature Range O QE 0 .4 900 TO +150 0 .5 600 -55 0 .6 700 Storage Temperature V 400 75 500 TSTG Reverse Voltage 190 V BR SPECTRAL RESPONSE 0 .7 300 ABSOLUTE MAXIMUM RATING (TA=25OC unless otherwise noted) SYMBOL PARAMETER MIN MAX UNITS APPLICATIONS Spectrometers Fluorescent analysers U.V. meters Colorimeters RESPONSIVITY (A/W) FEATURES Low noise U.V. enhanced High shunt resistance Quartz windows 5 200 1100 .18 pA nm A/W 10 V W/ Hz nS Information in this technical data sheet is believed to be correct and reliable. However, no responsibility is assumed for possible inaccuracies or omission. Specifications are subject to change without notice.**f = 1 MHz [FORM NO. 100-PDU-V109 REV N/C]
PDU-V109 价格&库存
很抱歉,暂时无法提供与“PDU-V109”相匹配的价格&库存,您可以联系我们找货
