PDU-V115
PDU-V115
    LUNAOPTOELECTRONICS(Luna Optoelectronics)
    TO-5
    PHOTODIODE UV 5.07MM SQ TO-5
PDU-V115 数据手册
PHOTONIC DETECTORS INC. Silicon Photodiode, U.V. Enhanced Photovoltaic Type PDU-V115 PACKAGE DIMENSIONS INCH [mm] WINDOW CAP (WELDED) Ø0.325 [8.25] Ø0.250 [6.35] 0.168 [4.26] 0.030 [0.76] 0.075 [1.91] CL WIRE BONDS 0.500 [12.70] MIN 45° Ø0.358 [9.09] 73° VIEWING ANGLE CL CL 0.200 [5.08] 0.035 [0.89] CL ANODE Ø0.018 [0.46] CATHODE Ø0.018 [0.46] HEADER PHOTODIODE 0.110 [2.79] SQUARE Ø0.100 [Ø2.54] ACTIVE AREA TO-5 HERMETIC CAN PACKAGE ACTIVE AREA = 5.07 mm2 +125 TS Soldering Temperature* +240 O IL Light Current C C mA 0.2 0.1 0 WAVELENGTH (nm) *1/16 inch from case for 3 secs max ELECTRO-OPTICAL CHARACTERISTICS (TA=25OC unless otherwise noted) SYMBOL CHARACTERISTIC TEST CONDITIONS MIN TYP ISC Short Circuit Current H = 100 fc, 2850 K ID Dark Current H = 0, V R = 10 mV Shunt Resistance H = 0, V R = 10 mV TC RSH RSH Temp. Coefficient CJ Junction Capacitance RSH λrange R V BR NEP tr 1200 -40 1100 Operating Temperature Range 0.3 900 TO O 500 C 1000 O 800 +150 700 -55 0.4 600 Storage Temperature % 00 =1 E Q 0.5 500 V 400 75 0.6 300 TSTG Reverse Voltage SPECTRAL RESPONSE 0.7 190 ABSOLUTE MAXIMUM RATING (TA=25OC unless otherwise noted) SYMBOL PARAMETER MIN MAX UNITS V BR APPLICATIONS Spetrometers Fluorescent analysers U.V. meters Colorimeters DESCRIPTION The PDU-V115 is a silicon, PIN planar diffused, U.V. enhanced photodiode. Ideal for low noise photovoltaic applications. Packaged in a hermetic TO-5 metal can with a flat U.V transmitting window. RESPONSIVITY (A/W) FEATURES Low noise U.V. enhanced High shunt resistance U.V. window 40 MAX UNITS mA 60 2 5 pA 5 GΩ H = 0, V R = 10 mV -8 % / oC H = 0, V R = 0 V** 500 pF Spectral Application Range Spot Scan Responsivity VR = 0 V, l = 254 nm Breakdown Voltage I = 10 mA Noise Equivalent Power VR = 10 mV @ Peak Response Time RL = 1 KΩ VR = 0 V 2 190 1100 .12 .18 5 10 .5x10 nm A/W V -14 500 W/ Hz nS Information in this technical data sheet is believed to be correct and reliable. However, no responsibility is assumed for possible inaccuracies or omission. Specifications are subject to change without notice. **f = 1 MHz [FORM NO. 100-PDU-V115 REV A]
PDU-V115
物料型号:PDU-V115
器件简介:PDU-V115是一款硅质、平面扩散、增强紫外线响应的光电二极管,适用于低噪声光伏应用。
引脚分配:文档未明确提供引脚分配图。
参数特性:包括反向电压(VBR),存储温度(TSTG),工作温度范围(To),焊接温度(Ts),光电流(Light Current)等。
功能详解:主要参数包括短路电流(Isc),暗电流(lo),并联电阻(RSH),并联电阻温度系数(TC RSH),结电容(CJ),光谱应用范围,响应度,击穿电压(VBR),噪声等效功率(NEP),响应时间(tr)。
应用信息:适用于光谱仪、荧光分析仪、紫外线测量仪、色度计等。
封装信息:封装在密封的TO-5金属罐中,带有平面紫外线传输窗口。
PDU-V115 价格&库存
很抱歉,暂时无法提供与“PDU-V115”相匹配的价格&库存,您可以联系我们找货
