PDB-708-FC
PDB-708-FC
    LUNAOPTOELECTRONICS(Luna Optoelectronics)
    TO-18-6
    PHOTODIODE FIBER OPTIC FC CONN
PDB-708-FC 数据手册
PHOTONIC DETECTORS INC. High Speed Detector Amplifier Hybrid Type PDB-708 PACKAGE DIMENSIONS INCH [mm] .205 [5.21] .162 [4.11] .500 [12.7] MIN PHOTODIODE CHIP 5 4 6 Ø.100 [Ø2.54] PIN CIRCLE Ø.184 [4.67] Ø.210 [5.33] Ø.155 [3.94] 3 1 PHOTODIODE OP-AMP 2 TO-18 6+0 HEADER 6X Ø.018 [Ø0.46] GLASS WINDOW CAP (WELDED) 0.062 [1.57] SQ Ø.0398 [Ø1.01] ACTIVE AREA TO-18 HERMETIC CAN PACKAGE WARNING: ESD SENSITIVE DEVICE ACTIVE AREA = 0.80 mm2 FEATURES 24 MHz bandwidth single supply operation Wide dynamic range DESCRIPTION The PDB-708 is a high speed PIN photodiode integrated with a wide band differential output transimpedance amplifier. It is Low power: 5 V @ 25 mA packaged in a TO-18, 6 leaded hermetic package. Options include, SMA, ST & FC type fiber optic ADMs. APPLICATIONS Fiber optic receivers Industrial controls High speed optical coupling Local area network SPECTRAL RESPONSE PHOTODIODE ABSOLUTE MAXIMUM RATING (TA=25OC unless otherwise noted) -40 +80 O +260 O Soldering Temperature* IL Light Current 500 C C mA 0.4 0.3 0.2 0.1 0 1200 Operating Temperature Range C 1100 O 900 +125 0% 1000 -55 0 =1 QE 0.5 800 Storage Temperature 0.6 700 TSTG TS V 600 Reverse Voltage 500 V BR TO 300 UNITS 400 MAX 300 MIN 190 PARAMETER RESPONSIVITY (A/W) SYMBOL 0.7 WAVELENGTH (nm) *1/16 inch from case for 3 secs max PHOTODIODE ELECTRO-OPTICAL CHARACTERISTICS (TA=25OC unless otherwise noted) SYMBOL CHARACTERISTIC TEST CONDITIONS MIN TYP MAX UNITS Short Circuit Current H = 100 fc, 2850 K ID Dark Current H = 0, V R = 10 V Shunt Resistance H = 0, V R = 10 mV 500 MΩ TC RSH RSH Temp. Coefficient H = 0, V R = 10 mV -8 % / oC CJ Junction Capacitance H = 0, V R = 45 V** 2.2 RSH λrange λp V BR NEP tr Spectral Application Range Spot Scan Spectral Response - Peak Spot Scan Breakdown Voltage I = 1 mA Noise Equivalent Power VR = 45 V @ Peak Response Time RL = 50 Ω V R = 45 V l= 900 nm 7 mA ISC 8.5 2 10 400 100 nA 2.4 pF 1100 nm 900 nm 300 V -14 1x10 3 W/ Hz nS Information in this technical data sheet is believed to be correct and reliable. However, no responsibility is assumed for possible inaccuracies or omission. Specifications [FORM NO. 100-PDB-708 REV A] are subject to change without notice. ** f = 1 MHz PAGE 1 OF 2 PHOTONIC DETECTORS INC. AMPLIFIER SPECIFICATION High Speed Detector Amplifier Hybrid Type PDB-708 (SO PACKAGE @TA = 25° C and VS = + 5 vdc CHARACTERISTIC UNLESS OTHERWISE NOTED TEST CONDITIONS MIN TYP MAX UNITS DYNAMIC PERFORMANCE BANDWIDTH PULSE WIDTH MODULATION RISE AND FALL TIME SETTLING TIME 180 3 dB 10 m A TO 200 m A PEAK 10% TO 90% TO 3%, 0.5 V DIFF OUTPUT STEP INPUT LINEAR INPUT CURRENT RANGE MAX INPUT CURRENT RANGE OPTICAL SENSITIVITY INPUT STRAY CAPACITANCE INPUT BIAS VOLTAGE NOISE INPUT CURRENT NOISE TOTAL INPUT RMS NOISE MHz ps ns ns 500 1.5 3 ±30 ±350 -36 0.2 0.4 ±200 DIE, BY DESIGN SOIC, BY DESIGN +V S TO IIN AND V BYP mA mA 1.6 dBm pF pF V 2.0 DIE, SINGLE ENDED AT POUT , OR DIFFERENTIAL (POUT - NOUT ) , CSTRAY = 0.3 pF f = 100 MHz DC TO 100 MHz 3.0 26.5 pA/√Hz nA TRANSFER CHARACTERISTICS TRANSRESISTANCE POWER SUPPLY REJECTION RATIO SINGLE ENDED DIFFERENTIAL SINGLE ENDED DIFFERENTIAL 8 16 10 20 37.0 40 12 24 KW W KW W dB dB 6 -1.3 1.0 600 50 20 -1.1 mV V V P-P mV P-P W +5 +11 ±5.5 26 OUTPUT DIFFERENTIAL OFFSET OUTPUT COMMON-MODE VOLTAGE FROM POSITIVE SUPPLY VOLTAGE SWING (DIFFERENTIAL) POSITIVE INPUT CURRENT, RL = ∞ -1.5 OUTPUT IMPEDANCE 40 POSITIVE INPUT CURRENT, R L =50 W W POWER SUPPLY OPERATING RANGE TMIN TO TMAX SINGLE SUPPLY DUAL SUPPLY +4.5 ±2.25 CURRENT 25 AMPLIFIER ABSOLUTE MAXIMUM RATING (TA=25°C UNLESS OTHERWISE NOTED) PARAMETER MIN MAX UNITS SUPPLY VOLTAGE ±4.5 ±12 V .9 mV +125 °C POWER DISSIPATION STORAGETEMPERATURE OPERATINGTEMPERATURE 60 -55 -40 +85 °C 1 2 3 4 5 6 PIN CONNECTIONS OUTPUT (+) PHOTODIODE CATHODE OUTPUT (-) GROUND/ CASE PHOTODIODE ANODE Vcc (5V) V V mA WARNING: ESD SENSITIVE DEVICE PIN 6 1 ANODE PIN 2 6 2 4 BOTTOM VIEW PIN 3 OUTPUT (-) + OP AMP - 5 3 Vcc (5V) PIN 5 CATHODE PIN 1 PIN 4 OUTPUT (+) GROUND Information in this technical data sheet is believed to be correct and reliable. However, no responsibility is assumed for possible inaccuracies or omission. Specifications [FORM NO. 100-PDB-708 REV A] are subject to change without notice. PAGE 2 OF 2
PDB-708-FC 价格&库存
很抱歉,暂时无法提供与“PDB-708-FC”相匹配的价格&库存,您可以联系我们找货
