PDB-C505
PDB-C505
    LUNAOPTOELECTRONICS(Luna Optoelectronics)
    PCB安装
    Photodiode 950nm 6ns PCB Mount
PDB-C505 数据手册
PHOTONIC DETECTORS INC. Silicon Photodiode, Photoconductive Fiber Optic Detector Type PDB-C505 Industry Equivalents MFOD71, 2FH250V PACKAGE DIMENSIONS INCH [mm] .320 [8.13] .300 [7.62] Ø.360 [9.14] Ø.350 [8.89] Ø.102 [2.59] Ø.092 [2.34] PLASTIC COUPLER NUT .100 [2.54] .036 [0.91] .026 [0.66] PLASTIC COUPLER HOUSING Ø.130 [3.30] Ø.120 [3.05] CL .280 [7.11] C L .270 [6.86] .320 [8.13] .300 [7.62] .205 [5.21] .195 [4.95] Ø.064 [1.63] Ø.061 [1.55] 2 PLCS .018 [0.46] .013 [0.33] TYP .062 [1.57] .042 [1.07] .675 [17.15] .625 [15.87] .750 [19.05] .700 [17.78] EPOXY POTTING C L CL ANODE CATHODE .840 [21.34] .760 [19.30] .105 [2.67] .095 [2.41] .100 [2.54] BOTTOM VIEW .300 [7.62] CL PHOTODIODE .023 [0.58] .017 [0.43] TYP .200 [5.08] C C L L FRONT VIEW .720 [18.29] .224 [5.69] .689 [17.50] ANODE CATHODE .100 [2.54] CL CL .177 [4.50] ANODE CATHODE Ø.059 [Ø1.50] .088 [2.25] .029 [0.75] .059 [1.50] WATER CLEAR C L SIDE VIEW .417 [10.59] .407 [10.34] .051 [1.30] PHOTODIODE .020 [0.50] SQ P.C.B MOUNT PLASTIC PACKAGE ACTIVE AREA = .18 mm2 APPLICATIONS DESCRIPTION The PDB-C505 is a high speed, PIN photoHigh isolation interconnects diode packaged in a low cost P.C.B mount Medical electronics plastic housing. Designed to interface with Consumer electronics 1000 micron core plastic fiber for short haul Micro processor fiber optic systems.Ideally matched with PDI-E521 IR or PDR-E526 red emitter. SPECTRAL RESPONSE ABSOLUTE MAXIMUM RATING (TA=25OC unless otherwise noted) 0.7 SYMBOL PARAMETER MIN MAX UNITS 0.6 IL Light Current +260 O 500 C mA 0.2 0.1 0 WAVELENGTH (nm) *1/16 inch from case for 3 secs max ELECTRO-OPTICAL CHARACTERISTICS (TA=25OC unless otherwise noted) SYMBOL CHARACTERISTIC TEST CONDITIONS MIN TYP Short Circuit Current H = 1000 lux, 2850 K 10 ID Dark Current H = 0, V R = 10 V .20 Shunt Resistance H = 0, V R = 10 mV TC RSH RSH Temp. Coefficient CJ Junction Capacitance λrange λp V BR NEP tr MAX UNITS mA ISC RSH 1200 Soldering Temperature* C 1100 TS +80 -40 900 Operating Temperature Range 0.3 1000 TO O 0.4 800 mW 0% 700 200 0 =1 QE 600 Total Power Dissipation 0.5 500 V 400 100 300 PD Reverse Voltage 190 V BR RESPONSIVITY (A/W) FEATURES High speed, 50 Mhz Low cost, PCB mount Includes connector Light tight package 20 nA 1000 MΩ H = 0, V R = 10 mV -10 % / oC H = 0, V R = 10 V** 5 pF Spectral Application Range Flooded D.C. Spectral Response - Peak Spot Scan Breakdown Voltage I = 10 m A Noise Equivalent Power VR = 10 V @ 850 nm Response Time RL = 1 KΩ VR = 10 V 500 400 50 1100 nm 950 nm 100 V -15 6x10 6 W/ Hz nS Information in this technical data sheet is believed to be correct and reliable. However, no responsibility is assumed for possible inaccuracies or omission. Specifications are subject to change without notice. ** f = 1 MHz [FORM NO. 100-PDB-C505 REV A]
PDB-C505 价格&库存
很抱歉,暂时无法提供与“PDB-C505”相匹配的价格&库存,您可以联系我们找货
