PDU-V401A
PDU-V401A
    LUNAOPTOELECTRONICS(Luna Optoelectronics)
    2-DIP模块
    Photodiode 360nm 1µs 2-DIP Module
PDU-V401A 数据手册
PHOTONIC DETECTORS INC. Silicon Photodiode, U.V. Enhanced Photovoltaic (center wavelength 360 nm) Type PDU-V401A PACKAGE DIMENSIONS INCH [mm] RED DOT INDICATES ANODE 0.313 [7.95] 0.303 [7.70] 0.071 [1.82] REF 0.070 [1.78] 0.062 [1.57] BLACK EPOXY FILTER Ag EPOXY ANODE BOND POTTING WIRE BONDS ±0.015 [0.38] 1.575 [40.00] Ø0.367 [9.32] Ø0.357 [9.07] 0.265 [6.73] LETTER "A" STAMP CERAMIC 0.127 [3.24] REF SOLDER PHOTODIODE CHIP ACTIVE AREA 0.096 [2.44] ACTIVE AREA CATHODE Ø0.020 [0.51] SnPb PLATED Cu PIN - 2 PLACES 0.105 [2.67] 0.173 [4.39] ACTIVE AREA CERAMIC PACKAGE 0.205 [5.21] ACTIVE AREA = 10.84 mm2 0.5 C mA 0.1 0 WAVELENGTH (nm) *1/16 inch from case for 3 secs max ELECTRO-OPTICAL CHARACTERISTICS (TA=25OC unless otherwise noted) SYMBOL CHARACTERISTIC TEST CONDITIONS MIN TYP ISC Short Circuit Current H = 100 fc, 2850 K ID Dark Current H = 0, V R = 10 mV Shunt Resistance H = 0, V R = 10 mV TC RSH RSH Temp. Coefficient CJ Junction Capacitance RSH λrange R V BR NEP tr 10 nm @ 50% 1200 Light Current O 0.2 1100 IL +260 C 0.3 900 Soldering Temperature* -40 0.4 1000 TS +85 O C 800 Operating Temperature Range O 0% 700 TO +100 0 =1 QE 0.5 600 -55 0.6 500 Storage Temperature V 400 TSTG 15 300 Reverse Voltage 190 V BR SPECTRAL RESPONSE 0.7 RESPONSIVITY (A/W) DESCRIPTION The PDU-V401A is a silicon, PIN planar diffused, U.V. enhanced photodiode. Ideal for low noise photovoltaic applications. The filter is a U.V. type A with a center wavelength of 360 nm, with 10-3 I.R. blocking. Packaged in a two leaded ceramic base. ABSOLUTE MAXIMUM RATING (TA=25OC unless otherwise noted) SYMBOL PARAMETER MIN MAX UNITS APPLICATIONS U.V. detection U.V. A sensor U.V. radiometer FEATURES Built in filter U.V. enhanced I.R. blocking 20 MAX UNITS mA 30 5 10 nA 200 MΩ H = 0, V R = 10 mV -8 % / oC H = 0, V R = 0 V** 1250 pF Spectral Application Range Spot Scan Responsivity VR = 0 V, l = 360 nm Breakdown Voltage I = 10 mA Noise Equivalent Power VR = 2 V @ Peak Response Time RL = 1 KΩ VR = 0 V 100 300 15 360 400 nm .10 A/W 30 V -14 1x10 1000 W/ Hz nS Information in this technical data sheet is believed to be correct and reliable. However, no responsibility is assumed for possible inaccuracies or omission. Specifications are subject to change without notice. **f = 1 MHz [FORM NO. 100-PDU-V401A REV B]
PDU-V401A 价格&库存
很抱歉,暂时无法提供与“PDU-V401A”相匹配的价格&库存,您可以联系我们找货
