PDB-C504-ST
PDB-C504-ST
    LUNAOPTOELECTRONICS(Luna Optoelectronics)
    PHOTODIODE BLUE FIBER OPTIC ST
PDB-C504-ST 数据手册
PHOTONIC Silicon Photodiode, Blue Enhanced Photoconductive DETECTORS INC. Hermetic Fiber Optic Detector Type PDB-C504-ST PACKAGE DIMENSIONS INCH [mm] CL CL .500 [12.70] .561 [14.27] .374 [9.50] CATHODE 2x Ø.018 [0.46] .077 [1.96] .230 [5.84] CL ANODE C .375 [9.52] L CL CL .410 [10.41] 3/8-24 UNF-2A THREAD .445 [11.30] PHOTODIODE ASSEMBLY Ø.273 [6.93] .100 [2.54] .125 [3.18] .066 [1.68] .046 [1.17] ACTIVE AREA .104 [2.64] ACTIVE AREA TO-46 ST RECEPTACLE ACTIVE AREA = 2.98 mm2 DESCRIPTION The PDB-C504-ST is a silicon, PIN planar diffused, blue enhanced photodiode. Ideal for high speed photoconductive applications. Packaged in a hermetic, TO-46 ST receptacle. -40 +125 O TS Soldering Temperature* +240 O IL Light Current C C mA 0.3 0.2 0.1 0 *1/16 inch from case for 3 secs max WAVELENGTH (nm) ELECTRO-OPTICAL CHARACTERISTICS (TA=25OC unless otherwise noted) SYMBOL CHARACTERISTIC TEST CONDITIONS MIN TYP ISC Short Circuit Current H = 100 fc, 2850 K ID Dark Current H = 0, V R = 10 V Shunt Resistance H = 0, V R = 10 mV TC RSH RSH Temp. Coefficient CJ 40 MAX UNITS mA 45 .15 1.0 nA 1.0 GΩ H = 0, V R = 10 mV -8 % / oC Junction Capacitance H = 0, V R = 10 V** 10 pF λrange Spectral Application Range Spot Scan λp Spectral Response - Peak Spot Scan VBR Breakdown Voltage I = 10 m A NEP Noise Equivalent Power VR = 10 V @ Peak Response Time RL = 1 KΩ VR = 50 V RSH tr 1200 Operating Temperature Range 1100 TO C 900 O 1000 +150 800 -55 0.4 700 Storage Temperature 0% =10 QE 0.5 600 TSTG 500 V 500 100 0.6 400 Reverse Voltage SPECTRAL RESPONSE 0.7 300 VBR APPLICATIONS Industrial controls Video systems Laser power monitors Fiber optic links 190 ABSOLUTE MAXIMUM RATING (TA=25OC unless otherwise noted) SYMBOL PARAMETER MIN MAX UNITS RESPONSIVITY (A/W) FEATURES High speed Low capacitance Blue enhanced Low dark current 0.5 350 1100 950 70 nm 100 V 1.5x10 -14 10 nm W/ Hz nS Information in this technical data sheet is believed to be correct and reliable. However, no responsibility is assumed for possible inaccuracies or omission. Specifications [FORM NO. 100-PDB-C504-ST REV A] are subject to change without notice. ** f = 1 MHz
PDB-C504-ST 价格&库存
很抱歉,暂时无法提供与“PDB-C504-ST”相匹配的价格&库存,您可以联系我们找货
