PDB-706
PDB-706
    LUNAOPTOELECTRONICS(Luna Optoelectronics)
    TO-99-8金属罐
    PHOTODIODE BLUE 5.07MM SQ TO-99
PDB-706 数据手册
PHOTONIC DETECTORS INC. Detector Amplifier Hybrid, Blue Enhanced Type PDB-706 PACKAGE DIMENSIONS INCH [mm] WINDOW CAP (WELDED) ±.002 [0.05] Ø.360 [9.14] (Industry Equivalent UDT-455 SD-100-41-21) .257 [6.58] .500 [12.70] MIN .106 [2.69] ACTIVE AREA SURFACE Ø.240 [6.10] Ø.325 [8.26] Ø0.120 [3.05] CERAMIC STANDOFF 67° VIEWING ANGLE 8X Ø.017 [0.43] .040 [1.02] .110 [2.79] SQ Ø.100 [2.54] ACTIVE AREA TO-99 HERMETIC CAN PACKAGE CAUTION: ESD SENSITIVE DEVICE ACTIVE AREA = 5.07 mm2 APPLICATIONS Medical diagnostic Low signal level applications Spectroscopy DESCRIPTION The PDB-706 is a low noise, medium speed, blue enhanced silicon photodiode integrated with a low noise JFET monolithic transimpedance op-amp. The feedback capacitor & resistor circuit are externally connected. Light Current O 500 C mA 0.2 0.1 0 1200 IL +240 C 0.3 1100 Soldering Temperature* 0 0.4 900 TS +70 O C 1000 Operating Temperature Range O 0% 800 TO +125 0 =1 QE 700 -55 0.5 600 Storage Temperature V 500 TSTG 15 0.6 400 Reverse Voltage 0.7 300 V BR SPECTRAL RESPONSE 190 ABSOLUTE MAXIMUM RATING (TA=25OC unless otherwise noted) SYMBOL PARAMETER MIN MAX UNITS RESPONSIVITY (A/W) FEATURES Low input bias current Low offset voltage 1 MHz bandwidth WAVELENGTH (nm) *1/16 inch from case for 3 secs max PHOTODIODE ELECTRO-OPTICAL CHARACTERISTICS (TA=25OC unless otherwise noted) SYMBOL CHARACTERISTIC TEST CONDITIONS MIN TYP MAX UNITS ISC Short Circuit Current H = 100 fc, 2850 K ID Dark Current H = 0, V R = 10 V Shunt Resistance H = 0, V R = 10 mV TC RSH RSH Temp. Coefficient CJ Junction Capacitance RSH λrange λp V BR NEP tr 45 mA 65 1.0 5.0 nA 2 GΩ H = 0, V R = 10 mV -8 % / oC H = 0, V R = 10 V** 15 pF Spectral Application Range Spot Scan Spectral Response - Peak Spot Scan Breakdown Voltage I = 10 m A Noise Equivalent Power VR = 10 V @ Peak Response Time RL = 1 KΩ VR = 10 V .5 350 1100 950 100 nm 125 2.5x10 15 nm V -14 W/ Hz nS Information in this technical data sheet is believed to be correct and reliable. However, no responsibility is assumed for possible inaccuracies or omission. Specifications are subject to change without notice. ** f = 1 MHz PAGE 1 OF 2 [FORM NO. 100-PDB-706 REV B] PHOTONIC DETECTORS INC. AMPLIFIER SPECIFICATION Detector Amplifier Hybrid, Blue Enhanced Type PDB-706 TA = 25° C and VS =± 15 vdc CHARACTERISTIC UNLESS OTHERWISE NOTED TEST CONDITIONS FEEDBACK NETWORK EXTERNAL TYP MAX UNITS - - - Ω 0.6 3.9 mV INITIAL OFFSET FULL RANGE VIO INPUT OFFSET VOLTAGE IIB INPUT BIAS CURRENT MIN LONG TERM OFFSET STABILITY .04 µV/MONTH OFFSET CURRENT, VCM=0 4 pA DIFFERENTIAL 1 X 10-12 COMMONMODE 1 X 10-12 Ω Ri INPUT RESISTANCE VICR INPUT VOLTAGE RANGE VN(PP) INPUT VOLTAGE NOISE COMMONMODE −12 +16 COMMONMODE REJECTION VCM ±10 V 72 90 VOLTAGE 0, f=1 KHz 2 µVPP VOLTAGE 0, f=10 KHz 40 nV/√Hz f=1 KHz 1 fA / √Hz UNITY GAIN, SMALL SIGNAL RL= 10 KW W CL= 100 pF 2 MHz IN INPUT CURRENT NOISE BOM FREQUENCY RESPONSE AVD OPEN LOOP GAIN VOM±OUTPUT CHARACTERISTICS VCC± POWER SUPPLY V SLEW RATE, UNITY GAIN 2.6 3.4 V/µs vo= ±10 V, RL=10 KΩ 20 230 V/mV VOLTAGE @ RL=10 K Ω ±13.2 ±13.7 V VOLTAGE @ RL= 600 Ω ±12.5 ±13 V OPERATING RANGE ±3.5 ±15 ±18 V WARNING: ESD SENSITIVE DEVICE PARAMETER SUPPLY VOLTAGE MIN ±4.5 INTERNAL POWER DISSIPATION MAX UNITS ±18 V 500 mW +150 °C 1- OFFSET ADJUSTMENT 2- INVERTING INPUT/ CATHODE OF PHOTODIODE 3- NON-INVERTING INPUT/ CASE GROUND 4- NEGATIVE SUPPLY VOLTAGE 5- OFFSET ADJUSTMENT 6- OUTPUT 7- POSITIVE SUPPLY VOLTAGE 8- ANODE OF PHOTODIODE POWER SUPPLY RATED @ ±15 V RANGE ±3.5 V - ±18 V QUIESCENT CURRENT 200 µA MAX PHOTOVOLTAIC Rf PIN 7 V+ PIN 2 5.1 mm 2 Ø 2.5 mm PHOTODIODE PIN 8 PIN 3 OP AMP + OPERATINGTEMPERATURE -55 PIN 1 Rf 0 +70 °C PIN CIRCLE 1 7 2 5.1 mm 2 Ø 2.5 mm PHOTODIODE PIN 8 5 3 4 PIN 7 V+ PIN 2 8 6 V+ 250 KOhm PHOTOCONDUCTIVE Ø.230 [5.84] STORAGETEMPERATURE PIN 6 V- PIN 4 AMPLIFIER ABSOLUTE MAXIMUM RATING (TA=25°C UNLESS OTHERWISE NOTED) V- PIN 3 OP AMP + PIN 6 V- PIN 4 PIN CONNECTIONS V+ 250 KOhm BOTTOM VIEW Information in this technical data sheet is believed to be correct and reliable. However, no responsibility is assumed for possible inaccuracies or omission. Specifications [FORM NO. 100-PDB-706 REV B] are subject to change without notice. PAGE 2 OF 2
PDB-706 价格&库存
很抱歉,暂时无法提供与“PDB-706”相匹配的价格&库存,您可以联系我们找货
