PDV-V403
PDV-V403
    LUNAOPTOELECTRONICS(Luna Optoelectronics)
    TO-5
    PHOTODIODE 600NM 17.74MM SQ TO-5
PDV-V403 数据手册
PHOTONIC Silicon Photodiode, Filter Combination Photovoltaic 600 nm (red color) Type PDV-V403 DETECTORS INC. EPOXY COVERING EYELET PACKAGE DIMENSIONS INCH [mm] WIRE BONDS EPOXY MARKING INK (WAVE LENGTH NO.) ACTIVE AREA SURFACE +- 0.005 [0.13] 0.080 [2.03] 0.200 [5.08] DIA PIN CIRCLE 0.365 [9.27] 0.355 [9.02] DIA 0.345 [8.76] 0.335 [8.51] 0.245 [6.22] 0.235 [5.97] DIA 0.500 [12.70] CHIP 0.330 [8.38] 0.320 [8.13] DIA 45° 0.020 [0.51] DIA 2 PLACES 0.035 [0.89] 0.030 [0.76] FILTER CAP SUBASSEMBLY ANODE CATHODE (CASE GROUND) HEADER 0.425 [10.80] 0.415 [10.54] ACTIVE AREA 0.223 [5.66] 0.123 [3.12] 0.135 [3.43] ACTIVE AREA TO-5 CAN PACKAGE 0.235 [5.97] ACTIVE AREA = 17.74 mm2 DESCRIPTION: The PDV-V403 is a silicon, PIN planardiffused, photodiode with a red color 600 nm +/- 2 nm CWL wide band interferance filter and a 65 nm half bandwidth. Ideal for photometry and radiometry measurement applications. +70 O C +240 O C TS Soldering Temperature* IL Light Current 0.5 mA 0.3 0.2 FWHM = 65 nm @ 7 5 % Tx MIN 0.1 0 *1/16 inch from case for 3 secs max 1200 -15 1100 C Operating Temperature Range 0% 10 900 O = 1000 +85 QE 0.4 800 -20 0.5 700 Storage Temperature 0.6 600 V 500 TO 100 400 TSTG Reverse Voltage 300 V BR SPECTRAL RESPONSE 0.7 190 ABSOLUTE MAXIMUM RATING (TA=25OC unless otherwise noted) SYMBOL PARAMETER MIN MAX UNITS APPLICATIONS Red color matching Color meters Film processing RESPONSIVITY (A/W) FEATURES 600 nm CWL 65 nm FWHM Low noise WAVELENGTH (nm) ELECTRO-OPTICAL CHARACTERISTICS (TA=25 C unless otherwise noted) SYMBOL CHARACTERISTIC TEST CONDITIONS MIN TYP O ISC Short Circuit Current*** H = 100 fc, 2850 K ID Dark Current H = 0, V R = 10 mV 150 MAX mA 200 10 UNITS 50 pA Shunt Resistance H = 0, V R = 10 mV 2 GΩ TC RSH RSH Temp. Coefficient H = 0, V R = 10 mV -8 % / oC CJ RSH .20 Junction Capacitance H = 0, V R = 10 V** 1700 pF CWL Center Wavelength (CWL, lo) +/- 2 nm 600 nm HBW Half Bandwidth (FWHM) 65 nm V BR Breakdown Voltage I = 10 m A N EP tr 50 75 Noise Equivalent Power V R = 10 mV @ Peak 9x10 Response Time RL = 1 KΩ V R = 10 V 1.0 V -15 W/ Hz µS Information in this technical data sheet is believed to be correct and reliable. However, no responsibility is assumed for possible inaccuracies or omission. Specifications are subject to change without notice.**f = 1 MHz, ***without filter [FORM NO. 100-PDV-V403 REV A]
PDV-V403 价格&库存
很抱歉,暂时无法提供与“PDV-V403”相匹配的价格&库存,您可以联系我们找货
