PDV-V418
PDV-V418
    LUNAOPTOELECTRONICS(Luna Optoelectronics)
    Through Hole
    PHOTODIODE 6.85MM SQ CERAMIC BLK
PDV-V418 数据手册
PHOTONIC DETECTORS INC. Silicon Photodiode, Visible Light Detector Type PDV-V418 PACKAGE DIMENSIONS INCH [mm] 0.071 [1.80] 0.236 [6.00] ANODE 0.138 [3.50] Ø0.018 [0.45] VISIBLE PASS I.R. BLOCKING FILTER 2 PLACES CL 0.193 [4.90] Ø0.315 [8.00] CATHODE 0.197 [5.00] CL HOLE INDICATES CATHODE 0.354 [9.00] 0.106 [2.69] 0.096 [2.44] ACTIVE AREA 0.112 [2.84] ACTIVE AREA 0.122 [3.10] CERAMIC PACKAGE ACTIVE AREA = 6.85 mm2 DESCRIPTION The PDV-V418 is a silicon PIN photodiode, with a built in visible pass, I.R. blocking optical filter. Housed in a black ceramic package with two leads. Designed for photovoltaic operation with 0 volt bias. Soldering Temperature* +240 O IL Light Current 0.5 C C mA 0.3 0.2 0.1 0 *1/16 inch from case for 3 secs max WAVELENGTH (nm) ELECTRO-OPTICAL CHARACTERISTICS (TA=25OC unless otherwise noted) SYMBOL CHARACTERISTIC TEST CONDITIONS MIN TYP ISC Short Circuit Current ID Dark Current H = 0, VR = 10 V Shunt Resistance H = 0, VR = 10 mV TC RSH RSH Temp. Coefficient CJ UNITS mA 7.45 1.0 1.5 GΩ H = 0, VR = 10 mV -8 % / oC Junction Capacitance H = 0, VR = 0 V** 800 λrange Spectral Application Range Spot Scan λp Spectral Response - Peak Spot Scan V BR Breakdown Voltage I = 10 mA N EP Noise Equivalent Power VR = 10 V @ Peak Response Time RL = 1 KΩ VR = 10 V tr H = 100 fc, 2850 K MAX 5.75 RSH 12 00 TS -20 % 11 00 Operating Temperature Range 00 10 00 TO C =1 80 0 +60 O QE 0.4 90 0 O 0.5 60 0 +80 -20 0.6 70 0 Storage Temperature V 40 0 10 50 0 TSTG Reverse Voltage 19 0 V BR SPECTRAL RESPONSE 0.7 30 0 ABSOLUTE MAXIMUM RATING (TA=25OC unless otherwise noted) SYMBOL PARAMETER MIN MAX UNITS APPLICATIONS Camera exposure meter Light meters Visible detector RESPONSIVITY (A/W) FEATURES Visible response Low dark current Good linearity Low noise 75 320 560 10 150 pA 1000 pF 730 nm nm 15 5x10-14 500 V W/ Hz nS Information in this technical data sheet is believed to be correct and reliable. However, no responsibility is assumed for possible inaccuracies or omission. Specifications are subject to change without notice. **f = 1 MHz [FORM NO. 100-PDV-V418 REV A]
PDV-V418 价格&库存
很抱歉,暂时无法提供与“PDV-V418”相匹配的价格&库存,您可以联系我们找货
