PDV-V404-46
PDV-V404-46
    LUNAOPTOELECTRONICS(Luna Optoelectronics)
    TO-46-2透镜顶部金属罐
    PHOTODIODE 550NM 2.98MM SQ TO-46
PDV-V404-46 数据手册
PHOTONIC Silicon Photodiode, Filter Combination Photovoltaic 550 nm (green color) Type PDV-V404-46 DETECTORS INC. PACKAGE DIMENSIONS INCH [mm] Ø.184 [4.67] .275 [6.99] .060 [1.52] .040 [1.02] Ø.155 [3.94] C L 0.500 [12.70] MIN 45° CL .100 [2.54] C L CL Ø.210 [5.33] .042 [1.06] PHOTODIODE .125 [3.18] .066 [1.68] ANODE Ø.018 [0.46] FILTER CAP SUBASSEMBLY CATHODE Ø.018 [0.46] HEADER .046 [1.17] ACTIVE AREA .104 [2.64] ACTIVE AREA TO-46 CAN PACKAGE 2 ACTIVE AREA = 2.98 mm FEATURES 550 nm CWL 70 nm FWHM Large active area DESCRIPTION The PDV-V404-46 is a silicon, PIN planar diffused, photodiode with a green color 550 nm +/- 2 nm CWL wide band interferance filter and a wide 70 nm half bandwidth. Ideal for photometry and radiometry measurment applications. ABSOLUTE MAXIMUM RATING (TA=25OC unless otherwise noted) SYMBOL PARAMETER MIN MAX UNITS C +240 O C Soldering Temperature* Light Current 0.5 mA 0.3 0.2 FWHM = 70 nm @ 75% Tx MIN 0.1 0 *1/16 inch from case for 3 secs max 1200 O 1100 +70 900 -15 1000 C Operating Temperature Range 0% 10 800 O = 700 +85 QE 0.4 600 -20 0.5 500 IL Storage Temperature 0.6 400 TS V 300 TO 75 190 TSTG Reverse Voltage SPECTRAL RESPONSE 0.7 RESPONSIVITY (A/W) V BR APPLICATIONS Green color matching Color meters Film processing WAVELENGTH (nm) ELECTRO-OPTICAL CHARACTERISTICS (TA=25 C unless otherwise noted) SYMBOL CHARACTERISTIC TEST CONDITIONS MIN TYP O ISC Short Circuit Current*** H = 100 fc, 2850 K ID Dark Current H = 0, V R = 10 V 35 MAX UNITS mA 40 150 300 pA Shunt Resistance H = 0, V R = 10 mV 6 GΩ TC RSH RSH Temp. Coefficient H = 0, V R = 10 mV -8 % / oC CJ RSH 1.0 Junction Capacitance H = 0, V R = 0 V** 340 pF CWL Center Wavelength (CWL, lo) +/- 2 nm 550 nm HBW Half Bandwidth (FWHM) 70 nm V BR Breakdown Voltage I = 10 m A N EP tr Noise Equivalent Power V R = 10 mV @ Peak Response Time RL = 1 KΩ V R = 0 V 30 50 5x10 V -14 450 W/ Hz nS Information in this technical data sheet is believed to be correct and reliable. However, no responsibility is assumed for possible inaccuracies or omission. Specifications are subject to change without notice.**f = 1 MHz, ***without filter [FORM NO. 100-PDV-V404-46 REV N/C]
PDV-V404-46 价格&库存
很抱歉,暂时无法提供与“PDV-V404-46”相匹配的价格&库存,您可以联系我们找货
