PDI-V488
PDI-V488
    LUNAOPTOELECTRONICS(Luna Optoelectronics)
    TO-5
    PHOTODIODE 880NM 17.74MM SQ TO-5
PDI-V488 数据手册
PHOTONIC Silicon Photodiode, Filter Combination Photovoltaic (center wavelength 880 nm) Type PDI-V488 DETECTORS INC. EPOXY COVERING EYELET PACKAGE DIMENSIONS INCH [mm] WIRE BONDS EPOXY MARKING INK (WAVE LENGTH NO.) ACTIVE AREA SURFACE +- 0.005 [0.13] 0.080 [2.03] 0.200 [5.08] DIA PIN CIRCLE 0.365 [9.27] 0.355 [9.02] DIA 0.345 [8.76] 0.335 [8.51] 0.245 [6.22] 0.235 [5.97] DIA 0.500 [12.70] CHIP 0.330 [8.38] 0.320 [8.13] DIA 45° 0.020 [0.51] DIA 2 PLACES 0.035 [0.89] 0.030 [0.76] FILTER CAP SUBASSEMBLY ANODE CATHODE (CASE GROUND) HEADER 0.425 [10.80] 0.415 [10.54] ACTIVE AREA 0.223 [5.66] 0.123 [3.12] 0.135 [3.43] ACTIVE AREA TO-5 CAN PACKAGE 0.235 [5.97] ACTIVE AREA = 17.74 mm2 FEATURES High transmission 10-4 rejection +/- 2nm CWL Match to 880 nm LED DESCRIPTION The PDI-V488 is a silicon, PIN planar diffused, photodiode with a wide band interferance filter. The detector filter combination has a wide 50 nm half bandwidth designed for low noise photovoltaic applications. Packaged in a TO-5 metal can. ABSOLUTE MAXIMUM RATING (TA=25OC unless otherwise noted) SYMBOL PARAMETER MIN MAX UNITS O C TS Soldering Temperature* +240 O C IL Light Current 0.5 mA 0.3 FWHM = 50 nm @ 75% Tx MIN 0.2 0.1 0 *1/16 inch from case for 3 secs max 1200 +70 1100 -15 900 Operating Temperature Range 1000 C TO 0% 10 800 O = 700 +85 QE 0.4 600 -20 0.5 500 Storage Temperature TSTG 0.6 400 V 0.7 300 100 SPECTRAL RESPONSE 190 Reverse Voltage Chemistry instrumentation RESPONSIVITY (A/W) V BR APPLICATIONS I.R. sensor GaAlAs LED sensor Spectrophotometry WAVELENGTH (nm) ELECTRO-OPTICAL CHARACTERISTICS (TA=25 C unless otherwise noted) SYMBOL CHARACTERISTIC TEST CONDITIONS MIN TYP O ISC Short Circuit Current*** H = 100 fc, 2850 K ID Dark Current H = 0, V R = 10 mV 150 MAX mA 200 10 UNITS 50 pA Shunt Resistance H = 0, V R = 10 mV 2 GΩ TC RSH RSH Temp. Coefficient H = 0, V R = 10 mV -8 % / oC CJ RSH .20 Junction Capacitance H = 0, V R = 10 V** 1700 pF CWL Center Wavelength (CWL, lo) +/- 2 nm 880 nm HBW Half Bandwidth (FWHM) 50 nm V BR Breakdown Voltage I = 10 m A N EP tr 50 75 Noise Equivalent Power V R = 10 mV @ Peak 9x10 Response Time RL = 1 KΩ V R = 10 V 1.0 V -15 W/ Hz µS Information in this technical data sheet is believed to be correct and reliable. However, no responsibility is assumed for possible inaccuracies or omission. Specifications are subject to change without notice.**f = 1 MHz, ***without filter [FORM NO. 100-PDI-V488 REV N/C]
PDI-V488 价格&库存
很抱歉,暂时无法提供与“PDI-V488”相匹配的价格&库存,您可以联系我们找货
