PDU-C108Q
PDU-C108Q
    LUNAOPTOELECTRONICS(Luna Optoelectronics)
    TO8-3
    PHOTODIODE UV 31.00MM SQ TO-8
PDU-C108Q 数据手册
PHOTONIC Silicon Photodiode, U.V. Enhanced Photoconductive Type PDU-C108-Q DETECTORS INC. PACKAGE DIMENSIONS INCH [mm] 0.215 [5.46] Ø0.483 [12.27] 0.065 [1.65] Ø0.449 [11.39] 1.500 [38.10] WIRE BONDS CL 69° VIEWING ANGLE Ø0.550 [13.97] 0.295 [7.49] ANODE Ø0.018 [0.46] CL CATHODE Ø0.018 [0.46] HEADER PHOTODIODE QUARTZ WINDOW CAP (WELDED) 0.265 [6.74] SQUARE 0.2472 [6.289] ACTIVE AREA TO-8 PACKAGE ACTIVE AREA = 31.00 mm2 DESCRIPTION The PDU-C108-Q is a silicon, PIN planar diffused, U.V. enhanced photodiode. Ideal for high speed photoconductive applications. Packaged in a TO-8 metal can with a flat quartz window. -40 +125 O TS Soldering Temperature* +240 O IL Light Current 500 C C mA 0.3 0.2 0.1 0 *1/16 inch from case for 3 secs max WAVELENGTH (nm) ELECTRO-OPTICAL CHARACTERISTICS (TA=25OC unless otherwise noted) SYMBOL CHARACTERISTIC TEST CONDITIONS MIN TYP ISC Short Circuit Current H = 100 fc, 2850 K ID Dark Current H = 0, VR = 5 V Shunt Resistance H = 0, V R = 10 mV TC RSH RSH Temp. Coefficient H = 0, V R = 10 mV CJ Junction Capacitance H = 0, V R = 5 V** RSH λrange R V BR NEP tr 1200 Operating Temperature Range 1100 TO C 900 O 1000 +150 0% 800 -55 0 =1 QE 0.4 700 Storage Temperature TSTG 0.5 600 V 500 30 400 Reverse Voltage 0.6 300 V BR SPECTRAL RESPONSE 0.7 190 ABSOLUTE MAXIMUM RATING (TA=25OC unless otherwise noted) SYMBOL PARAMETER MIN MAX UNITS APPLICATIONS Spectrometers Fluorescent analysers U.V. meters Colorimeters RESPONSIVITY (A/W) FEATURES High speed U.V. enhanced Low capacitance Quartz window Spectral Application Range Spot Scan 400 UNITS mA 460 5 32 MAX 15 pA 60 MΩ -8 % / oC 350 pF 190 1100 nm Responsivity VR = 0 V, l = 254 nm .12 .18 A/W Breakdown Voltage I = 10 m A 15 25 V -14 Noise Equivalent Power VR = 10 mV @ Peak 4x10 Response Time RL = 1 KΩ VR = 5 V 110 W/ Hz nS Information in this technical data sheet is believed to be correct and reliable. However, no responsibility is assumed for possible inaccuracies or omission. Specifications are subject to change without notice.**f = 1 MHz [FORM NO. 100-PDU-C108-Q REV N/C]
PDU-C108Q 价格&库存
很抱歉,暂时无法提供与“PDU-C108Q”相匹配的价格&库存,您可以联系我们找货
