PDI-V488-46
PDI-V488-46
    LUNAOPTOELECTRONICS(Luna Optoelectronics)
    TO-46-2,金属罐
    PHOTODIODE 880NM 2.98MM SQ TO-46
PDI-V488-46 数据手册
PHOTONIC Silicon Photodiode, Filter Combination Photovoltaic DETECTORS INC. (center wavelength 880 nm) Type PDI-V488-46 PACKAGE DIMENSIONS INCH [mm] Ø.184 [4.67] .275 [6.99] .060 [1.52] .040 [1.02] Ø.155 [3.94] CL 0.500 [12.70] MIN 45° C L .100 [2.54] CL C L Ø.210 [5.33] .042 [1.06] PHOTODIODE .125 [3.18] .066 [1.68] ANODE Ø.018 [0.46] FILTER CAP SUBASSEMBLY CATHODE Ø.018 [0.46] HEADER .046 [1.17] ACTIVE AREA .104 [2.64] ACTIVE AREA TO-46 CAN PACKAGE 2 ACTIVE AREA = 2.98 mm FEATURES 880 nm CWL 50 nm FWHM Large active area +70 O C TS Soldering Temperature* +240 O C IL Light Current 0.5 mA 0.3 FWHM = 50 nm @ 75% Tx MIN 0.2 0.1 0 *1/16 inch from case for 3 secs max 1200 -15 1100 Operating Temperature Range 900 C TO 0% 10 1000 O = 800 +85 QE 0.4 700 -20 0.5 600 Storage Temperature TSTG 0.6 500 V SPECTRAL RESPONSE 0.7 400 75 I.R. detector GaAlAs LED sensor 300 Reverse Voltage Chemistry instrumentation 190 V BR APPLICATIONS Spectrophotometry RESPONSIVITY (A/W) DESCRIPTION The PDI-V488-46 is a silicon, PIN planar diffused, photodiode with a wide band interferance filter. The detector filter combiMatched to 880 nm LEDs nation has a wide 50 nm half bandwidth designed for low noise photovoltaic applications. Packaged in a TO-46 metal can. ABSOLUTE MAXIMUM RATING (TA=25OC unless otherwise noted) SYMBOL PARAMETER MIN MAX UNITS WAVELENGTH (nm) ELECTRO-OPTICAL CHARACTERISTICS (TA=25 C unless otherwise noted) SYMBOL CHARACTERISTIC TEST CONDITIONS MIN TYP O ISC Short Circuit Current*** H = 100 fc, 2850 K ID Dark Current H = 0, V R = 10 V 35 MAX UNITS mA 40 150 300 pA Shunt Resistance H = 0, V R = 10 mV 6 GΩ TC RSH RSH Temp. Coefficient H = 0, V R = 10 mV -8 % / oC CJ RSH 1.0 Junction Capacitance H = 0, V R = 0 V** 340 pF CWL Center Wavelength (CWL, lo) +/- 2 nm 880 nm HBW Half Bandwidth (FWHM) 50 nm V BR Breakdown Voltage I = 10 m A N EP tr Noise Equivalent Power V R = 10 mV @ Peak Response Time RL = 1 KΩ V R = 0 V 30 50 5x10 V -14 450 W/ Hz nS Information in this technical data sheet is believed to be correct and reliable. However, no responsibility is assumed for possible inaccuracies or omission. Specifications are subject to change without notice.**f = 1 MHz, ***without filter [FORM NO. 100-PDI-V488-46 REV N/C]
PDI-V488-46 价格&库存
很抱歉,暂时无法提供与“PDI-V488-46”相匹配的价格&库存,您可以联系我们找货
